Any ideas, today my low beam stopped working, the high beam, and parking light still work, so i put a new bulb, but still the same problem, checked the new bulb, and it works fine, thanks in advance !!
stripped and cleaned the switch, covered the contacts with dielectric grease, still no low beam, thinking it might be the headlight relay !!
Headlight relay is attached to the front of the battery tray, the other relay with an orange wire is the indicator relay. I don’t think it will be the relay as the headlight is coming on, more likely a wiring problem too or from the switch you have just cleaned. You will have to chase down where the voltage stops.
