1 - 5 of 5 Posts
I was planning on putting this on a drag bike in the next year or so, but I'm way too busy with my street bike and land speed stuff. Not to mention my first child will be born this spring...
It's a generic turbo which I believe is a copy of a T-66. 46mm gate. This fits the factory radiator in the factory location. You do NOT need the muzzy oil relocator to use this, but you can if you want. It works with the low profile (much wider) oil filter that i use on all of the street kits. It is very tight and you will need to pop the big dump off to change the filter (4 bolts) OR you can use a 90 degree oil filter adapter for a zx14 to make things easier.
Will ship anywhere, in North America will likely be around 100-150 as a rough guess without boxing it up and getting weight and dimensions
2000usd takes it
Discussion Starter #2
More pics
I can finish this off for those interested in a complete system. this is basically the hard part, the rest is just odds n ends.
sold!
1 - 5 of 5 Posts
