1 - 20 of 86 Posts
2003 Ace Performance cyl head
A1 cams at 105/108 CL
2000 short block.
Cooper back cut trans
Stock crank and rods
KZScott preped Wossner 1199 turbo pistons.
Didn't want to let perfectly good parts sit on the shelf.... :)
Nice, R1 swinger sounds interesting!
Discussion Starter · #8 ·
How big a pain in the ass was the swinger and shock ?
Well
You would be amazed at how close it is.
The pivot shaft is the issue. A zx14 shaft, my custom fab threaded pivot shaft collar(that's the hard one). The inner pivot shaft tube needs to be fabricated to the 14 shaft. and a easy mod to a zx12 shock perch. A few other minor tweeks.
I'll get some better pics shortly.
Discussion Starter · #10 ·
The work that Scott puts into these turbos is tremendous. Getting this thing squeezed into a zx12r requires a lot of effort. I'm bolting the unit on and can really appreciate
the workmanship. !!!!
Wow thats cool, very stealthy!
Will the oil filter have clearance for removal?
yes i made sure it does as long as you use the filter i specd out for my systems
Wow... that is super clean. Any option for a filter? :nerd:
your local guy did the ram air nicer than the 2 i did, hes a pro for sure
yes ive done 1 with an inline filter pre turbo. very stealthy. im planning on doing my red bike the same way.
Henry's is similar to this one. Same turbo and header design. We use a shorter but much fatter wix oil filter
Lots of room ?
1 - 20 of 86 Posts
