1 - 3 of 3 Posts
hi guys a little help needed on another kwak a gtr1000 to be precise , i will be picking it up later all i need to know is will i be able to jump the start the bike with another battery ie car . the bike has been sitting in the garage for 12 years so not sure when the last time he would have started it . or do you think i might be able to charge the original battery :headscratch: i will be doing the usual checking first ie fresh fuel carb clean air filter any help will be great , he dropped it last time he used it and broke the left footrest and never used it again :thumbup:
Best to not use a car battery or a car which is running to jump start it. Good chance of damaging the stator and rectifier not to mention frying some of the wiring. Too much current available.
I wouldn't have much hope in charging a 12yr. old or older battery either.
After 12 years the battery will be dead.
Jump starting with a car battery may not be a good idea
Fit a new one.
Some one will chime in with some solid advice on the jump start.
Thanx Dave.
1 - 3 of 3 Posts
