1 - 15 of 15 Posts
Pulled the engine to check the valve cleances. Have to adjust a few of them. No big deal. Just wanted to share some pics with you guys.
For those who don't know what a "shim under bucket" valve setup is...this is a shim.
Notice the number 45 stamped on it. That's what you use (along with a dial caliper) to determine what the shim thickness is.
This is the "bucket"
The valve
The valve with the shim in place
and finally the bucket over the valve and shim
Discussion Starter · #3 ·
Glad I could help <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
Eric
00ZX-12R
Candy Persimmon Red
Eric did you already reassemble? I 'd be curious to know what things to watch for with cam removal, my 88 ZX-10 never required cam removal, had rockers on spring followers, made valve adjustments a snap. IYHO, is there really enough room to do the valve adjustments, without dropping the motor? oh yeah more pics would be great!
When Life Throws You A Curve Head For The Apex And Lean!!!!</p>Edited by: <A HREF=http://pub56.ezboard.com/bkawasakizx12r.showLocalUserPublicProfile?login=sleepr>sleepr</A>
at: 3/20/02 8:48:27 pm
Excellent photage Eric.
Your hands are too clean though, you must use the same citrus based hand cleaner I do!!!! LOL
"You must be fast, 'cause I was haulin' ass when I passed you."</p>
Discussion Starter · #7 ·
Wow,when I saw "pulled motor to check valves",I thought ya tilted it forward.You don't mess around!Nice to know what it looks like in there.Thanks!I also have a '00 red 12R,with 9000 miles,and have'nt checked 'em yet.Better get in there,huh?
That look's like a lot of work to adjust valve's. Thank's for the pic's.
2001 ZX12R Ninja,
Phantom Silver" Something which exists but has no physical reality; A ghost" </p>
Discussion Starter · #10 ·
Since it's going on the site, if it's not too much trouble I would like to see
sort of a "How to" documentation. I'll be doing my own next winter and it
would be very helpful to have something to refer to. Thank's Eric.
hay eric this is killer. you better get every horse you can get cause i have a pc3r and powershifter on my 12 and were gonna go at it agian. cant wait. what were before and after shim sizes.hope lifes been treating you good.see ya .....mark
Discussion Starter · #13 ·
Sorry guys have been working a lot. Keeping me off the boards.
Sleepr, haven’t put it back together yet. Just got the needed shims that I need to make my adjustments today.
Should go back together by this weekend.
I would say there is enough room to check the valves with the motor in there. I don't know about making any changes. I am very anal about my stuff and like to have everything perfect. The best way to do the best job in my opinion is to go ahead and pull the motor. If you are mechanically inclined, it's easy. Hardest part was getting the front sprocket off. It's supposed to be at 98 ft/lbs and I swear it was on at about 150 ft/lbs from the factory <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> .
Blitz, as I said before, I'm very anal <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> I clean my hands before I get into the engine. The only place I got "dirty" was when messing with the chain and front sprocket.
Topendrush, I checked the valves when the bike was stock at about 7500 miles. At about 9000 miles I installed Akro, PCIIIR, and K&N's. I'm at about 11800 miles and decided I wanted to check things out now that it’s had some miles on the "new" setup. Valves were all in spec @ 7500 miles. I now have 2 valves that are out of spec (too tight). Since I've got things torn down, I'm adjusting all valves to be on the "loose" end of the spec.
Silver, as stated above, now at about 11,800 miles. I've heard everything from check them at 1000 miles then 15000 miles to check them at 7500, 15000, then not worry about them. I just checked them at 7,500 because I had nothing better to do <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> . High performance engines require high performance maintenance. To each their own but I like to make sure I'm getting maximum hp and performance. At 9,000 miles with the Akro and PCIIIR I pulled 171 hp when it was 96 degree's with 90 % humidity (after getting a custom map made the same day). When I get the valves done, I'm going to get it run again and see if there is any difference.
Wardawg, Not really a lot of work. It is actually therapeutic for me <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> Working with computers all day it's nice to be able to come home and take something apart and put it back together. Very constructive <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
Eric
00ZX-12R
Candy Persimmon Red
</p>Edited by: <A HREF=http://pub56.ezboard.com/ueric00zx12r.showPublicProfile?language=EN>Eric00zx12r</A> at: 3/21/02 12:43:12 pm
Discussion Starter · #14 ·
Hey Killer, long time no comms. Shim size changed on almost all 16 valves. They didn't all need it, but I wanted to put all valves at about the same clearance and just on the loose side of the speced range. running mostly 60's on the intake and 45's on the exhaust.
My foot is never going to be as fast as that damn air shifter...but it will be fun none the less <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D">
Hopefully this summer we can get together more with Alan and do more ridding. My year looks pretty bleak untill after June <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/frown.gif ALT=":(">
Eric
00ZX-12R
Candy Persimmon Red
1 - 15 of 15 Posts
