Greetings,
I've got a question about SWINGARM SPOOLS for ya,
Just got a set for the 12 and I'm puzzled (no instructions).
The spools came with 2 bolts,2 spacers and 2 O-rings
but I'm not sure how they go on.:puzzled:
I'm guessing the spacer would move the spool out (to clear the swingarm)
BUT where does the O-ring go ???
Any help appreciated.
Take Care,
Gav
Greetings,
Take Care,
Gav
Can you show us a pic of the spools if ok ?
You do mean rear stand /slide spools that bolt into the swing arm ?
Discussion Starter · #3 ·
Hey maxumis,
Yeah the rear stand /slide spools.
Here's the spools I got.
You can see the O-Ring next to the spacer.
Hey maxumis,
They look awesome mate !! don't really know why the 0 rings are there ? could be some sort of locking thing like a lock washer or to help seal the CF?
Mine didn't come with 0 rings , sorry I am just guessing ..
Are they not just fitted to the screw just to hold the two parts together in transit ?
Either that or ,if the swingarm has a chamfer on the threaded part, the o-ring is to stop moisture creeping into the threads ,once fitted.
Kendo
I don't see a reason for the o-rings. I have never installed them on swingarm spools. I normally use a little blue loctite on the threads when installing.
Discussion Starter · #7 ·
Thanks Guys.:thumbup:
I'll have a go fitting'em in the morning.
Maybe some pics too.
Been busy polishing the passenger peg bracket (left side).
A buggar to get the "coating" off but it shined up NICE.
Thanks again for the replies.
cheers
Gav
