1 - 5 of 5 Posts
I was reading the October Motorcyclist and came across the Long Term Report re: the 12R. Boehm(editor) mentioned something about a Kawasaki rear shock shim kit which raises the rear ride height without ruining ride quality and bump compliance by jacking up spring preload.
It allegedly makes the 12R steer more crisp around the twisties. My question is this.....has anybody done such a mod to their ride, and if so, what's your opinion?
The Kawasaki shim kit costs $162.00 and includes a 1mm, 2mm, 3.2mm, and two 4.5mm shims. Though, the same mod can be made with a 17mm fender washer for about 39 cents.
Thanks in advance
Bert
Moderator
use the washers....lol....knotch em and slip em in..........
shims
Hey Epstein, did you do it to your 12R?
Bert
Moderator
I had mine out when I chromed the swing arm so I didnt have to notch the washer.......I have seen the notch method done and it works...... Brian
Do you keep changing shims till it feels better ? whats the most common mm shim stack being used ? the ass end is already jacked up like an old hot rod 8)
1 - 5 of 5 Posts
