rear tires
1811 Views 5 Replies 5 Participants Last post by  Marcos Peguero
Has anyone replaced their rear tire with a 180 width instead of the OEM 190? Do you recommend it for quicker handling?
Thanks,
As far as my experience goes, If you drop the width on the rear you flatten the contact making the initial turn harder with a very abrupt lean on the outside. it would be better to swap rims with a C model 9, drop the front, raise the rear, or lower the profile on the front tire. (not width)
You are probably going to steer a little faster, but at the same time you are going to have less contact area. I would not do it, but it is just me. I am running stock sizes on both bikes, 9R and 12R.
It's fine with a 180. Check out my findings about my new M1's in this thread
To be fair The Fruit Bat is right about the tire shape if you try to go too far from stock but the 5.5 inch rear on our 9's is within the suggested range for 180's according to the Dunlop fitment guide. Of course this may all change for specific tires. But I can offer you a hearty thumbs up for the M1's with a 180 rear.
either
From (my) roadracing experience, the 190 offers a little better traction when gassing it out of slower corners. The 180 made my bike turn a bit faster and a lot easier. I chose to run the 180 so I could get the bike in on the brakes quicker for passing and just gave another 10% attention to throttle control. It also helped me not get tired as fast when endurance racing.
I use BT020 180 tyre, it feels very easy to turn.
