1 - 2 of 2 Posts
So with my limited skills I've disconnected power commander and put standard can on. After the passing of a couple of months I fired it up and it was fine, no black smoke, took it for a run it was fine for first 5 mins, then it started playing up. If I rip the throttle it misses then jerks forward. It seems to get worse as time goes on. The temperature is fine. After reading similar symptoms on the forum I've accumulated a TPS Sensor, set of coils and a water temp. Sensor. I now need help trying them. If anyone has any ideas, can point me in the direction of a decent mechanic, near me, whose worked on these. Or fancies ago themselves please get in touch. Mad **** you seem very knowledgeable and live close to me. Give us a shout if you have any advice. Cheers . Ste
They are all very easy to change if you have the basic tools...the only thing special you need is a digital volt meter to set the tps to the right voltage
1 - 2 of 2 Posts
