running on one cylinder carb question
2K views 0 replies 1 participant last post by  Perfecte99
#1 ·
Hi this little ninja is driving me bananas,..
Its running poorly and at idle seems one cylinder is totally dead,
Heres where it gets fishy, the spark on the dead cylinder is good...
And when i cover the airbox holes the revs rise...
So just double checking as i already cleaned and checked the carbs for vac leaks.
Blocking the airbox the revs rising means a vacuum leak correct?
I already know yes but im tired of pulling the carbs on and off again and just figured id shout out to all u much more knowledgeable than i to doublecheck before offing then again
