1 - 12 of 12 Posts
I've got the faster red model with polished wheels. Somehow (I won't bore you with the details) I've scratched the polished portion of the wheel. The gouge is fairly significant (thumbnail stops in it). Is there a good way to polish/sand it out?
thanx
BDO
Discussion Starter · #3 ·
Sound's kinda deep, but that's ok. I'm not sure what
kind of buffing tool's you have if any so I suggest looking
at this site- www.medicaremanager.com/tarheel/
It is not necessary to have a buffer. You can use the
same set up as I use for cleaning. A drill, about 6 inches
of 1/2 inch all thread, a couple of buffing wheel's (6 inch
work's good), and a couple of nut's and washer's to hold
the buffing wheel's. Put on end of the all thread in the
drill. The other end put on your nut, washer, buffing pad,
washer, and nut. Get an abrasive pad with and abrasive
compound and go to work. The scratch will come out. Then
of course use the softer wheel with the polishing compound
to shine it back up.
This set up is great for cleaning polished part's. I hardly
ever use metal polish. This is where it's at.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D">
Discussion Starter · #5 ·
I'm sure no one can see the scratch at 195 mph, since you have the BAD ASS RED 12, i'm sure you've been there once or twice.....
I've got another method, No buffing required.
Take spoon from the kitchen, a regular spoon. Find the direction materal is gouged,
Take spoon and push materal back into depression. All your doing is refilling the gouge with the materal pushed out.
Work's on Aircraft
Discussion Starter · #11 ·
Of course nobody will see a scratch at 195mph. Not even
at 5mph. The fact is our bike's spend the most time at 0 mph.
It's no big deal to some, but other's would rather not have
it. Hell I enjoy working on mine.
1 - 12 of 12 Posts
