1 - 20 of 24 Posts
ya went to the track today only running 1/8 clowdy and wet best 60 was a 1.78 spinning bike ran 6.38 at120 in 1/8. but ran out the whole 1/4 every shift could hear it slip on higher gears shut her down and clutch puller broke clean off at the tip. any one ever had this happen.thinking of ordering a hayes any one tried one.
clutch pack way low??
whats the air gap?
ummmm.....
"clearance between buttons and arms" then.
Normally its the arm that chips but the puller usually survives :headscratch:
I use a single stage MTC lock up that took a long time for me to get set right for the tracks I use most but I bought a Hays last year and have not fitted it yet because we got the MTC to work properly.Project one this Winter.
I dont know if there are any more Hays available new but you might find one used or a MTC multi stage both can be tuned much more than the single stage.
Discussion Starter #11
Dont know what you mean by the arm chips .if you could shed some light on the arms . I will putting it back to gether tonight thanks
Discussion Starter #14
Ya found that the clutch was worn so bad that the shaft would push the puller before it would pull on it
ya I got .135 mtc plate to pressure plate [/ATTACH]
a little big, but not enough to cause that issue, just worn out parts. Im guessing caused by trying to pull the clutch in with that crazy amount of weight on the arms. i have nowhere close to that much with my turbo bike....
Discussion Starter #16
Ya looks like alot of weight thats how i got it thinking of removeing the washers .I was thinking of runing 4 springs insted of the 6 on presure plate so it would slip a little on the launch last time she spun then hooked up brought rpms right down .
Discussion Starter #17
Looks a little heavy may be take washers out.was thinking of running 4 springs on the lockup insted of the 6 let slip a little in the launch leep the rpm up?
take all the bolts off, not just the washers. 4 springs would be a good starting point
theres are minor changes, the parts are all interchangeable
1 - 20 of 24 Posts
