Hi everyone,as previously mentioned,I have been restoring this zx12 for quite a while.
Whilst in the process,I pulled the starter motor down,and discovered it was badly contaminated with oil.
Turns out that the seal (that's unavailable to purchase separate)what is it with Kawasaki c'mon man!!
Anyway I got one made for me,and that was sorted,so decided to put new brushes in whilst stripped down.
This is where,I would like to give the heads up to anyone doing this repair.don't buy cheap brushes off internet!
I did notice at the time of fitment they looked inferior to the oem brushes i was replacing,but went ahead.
Anyway fast forward to this week,and the moment of fruition,where all my hard work culminated in the inaugural start up.she fired up after a few primes,but was sluggish cranking.After idling and getting her up to temp,and checking for leaks,fan operation etc,I turned her off.tried 're start and had classic flat battery symtoms.
After exhaustive checks on wiring,checking for voltage drop,I even ran slave cables by passing solenoid harness,and also ground cable.I'm afraid my cheap brushes were to blame,just not up to carrying the current required for armature and starter operation.Cheap isn't always cheerful guys.regards roy.
