1 - 14 of 14 Posts
1. Is the 16/44 gearing the dragstrip choice or preference? 2. And anybody using the new Micron Serpent exhaust? What kind of power gains made?
Some use 16-44=2.75 others use 17-47=2.76, I don't know much about the Micron pipe... here its a good one though.
Most guys are running the 16-44 because it adds to the wheelbase!!!...If Rickey Gasdon is running a 16-44 then why shouldnt you???
Dont know anyone running the Micron...The 3 popular pipes for the 12 are Akrapovic, Muzzy, Hindle step...
I have the Muzzy on the 2000, not too happy with the performance below 3500RPM...
Have the Akrapovic on the 2002 and its a great pipe in everyway!!!...Performance, fit, quality finish, I should have put it on the 2000!!!
A few guys really like the Hindle,but it has some fit issues, But performes well...
CrotchRocket
Hindle fit issues
I am curious about the Hindle step pipe,for an 02...But Crotch Rocket wrote about fit issues.What are the fit issues with this pipe?
Mono was running the Micron, I believe, and I think the can came apart :shock: rivets or something fell out.....
Ping him on the 12 forum for more info.....um, correct info :wink:
Boost
appears 16/44 combo gets the full use of the existing swingarm. I'm running a bolt on extension as well, but still use the 16/44 because since I'm used to it and want to change one thing at a time. I also run the Micron Serpant and am very happy w/the results. 153 SAE bone stock and 168.6 after pipe and EMS - Stock air filter. Went to another dyno and got 175 SAE where an '01 with Akro, custom map, K&N's, Muzzy fuel pump, crank case vac pump upon other mods only netted 177. (different day, so who knows)
Put a clone of King's NOS system on and got 258! Seems to love NOS!!!!
fastestr1 runs a step Hindle. Helped him install it and it was a breeze. No fit up problems at all and he seems happy with it.
My 2 cents worth.
Yes it got me into the 8.90's with a stock motor on NOS. So I would say I am very happy 8)
Fast- Is that with an extended arm and if so what length?
Steve
Yes it is with the 4-7 inch bolt-ons, I am around 63 inch total.
1 - 14 of 14 Posts
