1 - 8 of 8 Posts
hi everyone, I'm pretty new here, Introduced myself a little while back when I bought my 02' 12R. so I've gotten to taking it apart and giving it a really good cleaning and took the air filters out in the process. I would like to replace them and would like to use a set of BMC filters as replacements, not so much for the power gains but more for the fact that I can clean them and not have to buy new oem's at $80+ per set. so my question is, if I use the BMC filters and and then down the road install a bolt on Yosh RS3,will I then require a PowerCommander also or are filters and a bolt on not enough of a upgrade to require the Pc3?
I have a 2000 A1 with k&N air filters and a bolt on Yoshi, it runs really well as it is without a power commander.
No doubt it would run better with a PC3 and a custom map, but it runs just fine without one.
not needed, its the header that necessitates a map change
As mentioned above I have BMC's and Yoshy RS3 without needing a PC; she runs great and sounds fantastic :thumbup:
Thanks guys,pretty plain and simple, I don't mind spending the money if I needed to,but if I don't need to then that's even better:thumbup:
Just to add my 2pence. I have a set of filters and an end can. I run a Pc3 with a custom map and it does run better than without. If you can get a cheap one is worth it, if your looking at a new one then dyno time I wouldn't bother.
I removed the Kleen Air, ripped out the cat, added K&N filters and a Scorpion end can. At the same time I had a PC3 fitted and dyno mapped.
Power and torque on the graphs were up a little and they were a bit more linear but I really couldn't tell the difference performance wise.
It definitely sounded better (louder). I do think the PC3 made getting on and off power in traffic at 20-30mph a bit smoother. Maybe I just got more time on the bike and improved my throttle control.
Fuel economy was not improved at all by the PC3.
You can clean the oems with gas ya know.
1 - 8 of 8 Posts
