Anybody know what stock valve spring pressures are at a known installed height? They don't really spec. it in the manual, just free length #s for both Int and Ex.
I felt mine were weak so they got pulled while it was apart and new ones from KW purchased.
Well, I had time during the holidays too muck with it and was re-assembling the cylinder head with different cams (Kent, I have never run them) and KW dual valve-springs, and I dont feel good about it...they are like compressing rocks and I can't turn the cam with all tightened. The head is off the bike, so its just my hand on the cam gear. I will try again with some soft channel lock pliers and then I will drop to one single spring and try again, with a oem cam if necessary.
I measured a couple KW springs and both were at or above spec 65# at 1.375"
I maybe bought too much spring for a 0.375 VL cam. Im now nervous about stressing the cam chain with so much pressure and I no longer have oems to measure.
I guess my next step is to put in weak hardware store springs and measure my installed height and rotate cams and check for binding.
