@ verge of buying a 1999 ZX7R-750, 'presuming that I can fix it!' OK the guy said that it ran well prior but became hard starting- thought carbs needed cleaning so he sprayed carb cleaner while trying to crank in his garage. Said that it was so loud that he kept holding down the start button for good while after it actually had started. Now the problems are that the starter just kinda clicks and whirrs, and the carbs leak fuel. I would like to (need to-$$$) fix this myself. He said delicate matter to balance 4 carbs- don't wanna run one lean and burn it out- needs a certain pressure meter to balance, etc. Also, I need a link to where to download a service manual (shop manual best) that is ACTUALLY FREE. What is maintenance schedule for this bike- 8K minor/16K major? Any other suggestions? PS- I trust this guy, Also- (big one!), bike has an NOS system semi-installed- he said never used yet- would that be problematic?
PLEASE- someone help and suggest which starter parts or kit to get, same for carb, and info on cost/description of this pressure meter- THANX MUCH, V
