i got a foam filter but need the plastic cage. Can it be installed without the cage? Im tring to get rid the KN filter.
It would probably get sucked into the carbs. Can you not just recharge your K&N filter?
Tring to get back to stock, that kn filter looks more restrictive and less even airflow to the carb throats compared to foam. im getting excessive fuel reversion in the airbox. suppose to get alittle fuel and blow by in the catch can.
Don't do it without the cage. It will get sucked in for sure. If it tears and chunks make it past the carb they melt to the intake tract and cylinder wall. Bad things happen immediately after that.
