1 - 20 of 86 Posts
Hi all my front end on the old 12 has not been feeling to grand as of late so i am treating her to a new front :lol:
I am waiting on the forks triples and calipers from an A7F zx14 to turn up this week, but in the mean time i have stripped the old setup from the 12.
I have noticed that the top bearing on the steering stem is smaller the the bottom bearing on the stem 25mm top internal diameter and the bottom is 35mm ID.
This means that i will have to machine the zx14 steering stem to accomodate the smaller top bearing. Newer generation 12s have the same size bearings top and bottom so its nearly a straight swap to my annoyance !:rant:
Will post some more progress in the week when the forks arrive.
excellent, i was going to look into pressing the stems out and swapping them. also in the weapon x thread of Shanes is gunners drawing of the machining necessary to make a stem. :thumbup: cmg
The stem on the 12 is one very tight fit and will need a press for sure to remove.
Im going to see if the diameters are the same then i will make the decision wether to swap the shafts or just machine the zx14 one to suit as i have access to a machine shop to turn and thread the correct diameters.
Thanks Mr Kawasaki for making thing a bit more difficult !
Got both my front and rear zx14 wheels and rear calliper and will test mount the rear tomorrow to see if the calliper will fit on my zx12 arm.
The steering stem can be pressed out and used in the zx14 yoke as i have today spoke to someone who has done it so for all those that want to do this conversion on their a1 a2 it can be done with relative ease.
Is it weird that this pic has me excited :lol:?
I would love to set-up my 12 with these gold wheels :super:, but my current cash flow situation cannot support it :thumbdown: I will look into this in the future, though :clap:
Subscribed to thread to see the outcome. Good luck :thumbup:!
Right more progress today.
The zx14 rear wheel is a straight swap using the zx14 disc and calliper the sprocket pcd is the same on zx12 and 14 as is the cush drive but they look slightly different,Spindle is also near identical with different chain adjusters only which still fit.Everything lines up perfectly.
zx14 cush drive fitted to zx12 wheel for comparison
Discussion Starter #11
On the front yes, but no issues on the rear if you use zx14 caliper and disc its straight swap as the zx14 rear disc is bigger and looks as if it is offset a little more on the zx12 wheel so you would have to do some modification to the zx12 calliper mount if you wanted to go down that path.
The spacers on the zx12 and rear spindle are identical to the zx14.
Front requires a lot more work as i will be detailing over the next week.
Discussion Starter #12 (Edited)
Right today i have taken the stem out of my zx12 triples which was easy !
Did a few measurements on the zx12 and zx14 front wheel spindles and they are pretty much the same apart from the spacers on the zx12 they measure 21.5mm on the zx14 they are 13mm. The zx14 spacers are crap and made out of alloy so will wear and corrode very quickly so I'm going to machine the steel zx12 spacers to 13mm as these will last a lot longer and seal better within the bearing seals.
The stem if you require to press it out pushes out through the bottom of the yoke so put pressure on the threaded end down.
Notice the lip in the bottom of the yoke this is where the bottom of the stem has a cir clip and locates in when shaft is pressed in.
The rest of my kit will be here on Saturday so more pics will follow then.
If you are using the 14 triples there are no front wheel issues.
Everything will be the same as the 14.
It only becomes an issue using the 12R triples with the 14R front end.
I think he was modding the steel 12r wheel spacers so they are the same thickness as the 14 ones, only because he wants steel spacers instead of alloy.
Maybe.. he just mentioned earlier about the rear bolting on, but the front having issues "to be detailed later"
Discussion Starter #18
If you are going to use the a1 a2 stem on the 14 triples there is another issue the top triple will require a bush as the diameter of the stem on the 12 is smaller than the 14 one.
1 - 20 of 86 Posts
