1 - 20 of 23 Posts
the bike overheats within 10 km of riding, i have changed the coolant and oil, but still the same, what can i try next, the temp goes past red.... HELP
does it overheat while riding or just sitting at a light? do you hear your cooling fans coming on? did you check the coolant level?
Kinda having the same problem after i changed the coolant. But mine is fine while riding, but at light's the temp jump's up quickly. City riding the fan almost run's constantly.
Here we all respond to a new member and he is not checking the board! Here I even know someone in ZA and really could give him some help there!
+1 My 12r is the same... I believe from what i have read that hot running is common 12s, My fans cope very well though, they seem to keep the temp needle 1 below hot but when you get on the open road it cools straight away which is fine in my book.
There are major upgrades for radiators which cost a mint with better fans but not sure who makes them...:puzzled: but its one of my next upgrades when i got the cash....:thumbup:
You gotta burp the cooling system by letting the bike run and get hot with the cap off.
Make sure the overflow tank is not dry or you'll just suck air back into the system as it cools.
The 12 has an air pocket in the cylinders that'll trap air until things start getting hot and moving around. Lightly tapping on the cylinder bank with a soft rubber mallet seems to coax the air out as the coolant reaches hot.
If you really want to cool her down, run distilled (always used distilled regardless) water and Water Wetter. You can add some coolant if you like, but the 50/50 mix is a killer on heat transfer.
In the summer I run 1 cup coolant, and the rest distilled water/Water Wetter mixed as recommended. Makes a HUGE difference. Just do not forget to flush it and 50/50 anti-freeze it well before freezing weather if you live in the snow belt. A cracked block is no laughing matter. ;-)
Basically how i did it. i still think there's air trapped because every time the fan came on it would spit coolant up. i'm running coolant, distilled, and water wetter. How many bottle's of water wetter do you run? Also if the bike is running lean, would the also cause it to run hot?
my bike gets hot at lights then cools on the road i also put a muzzy fan on it the newer model 12's have two fans im thinking of adding another fan
Well, I've never met a zx-12 that doesn't run on the hot side.
Mine will blow the fans all day long in stop and go traffic with coolant in it.
I use 1/2 a bottle of Water Wetter, which is half what they recommend for a car. Trust me, it makes a HUGE difference over 50/50 antifreeze.
Water Wetter claims 20 degrees F cooler and I believe them.
Also, I wrap my header pipes. That makes a difference too, not only on the heat pouring onto your legs, but the air-box is cooler which = more HP.
Win/Win
Win/Win
I also wrapped the header, but it's only down to the collector
Because of buying Hong Kong fairings that couldn't take the heat, I ceramic coated my headers at NitroPlate in Nashville. (We used this supplier for applications at Peterbilt when the exhaust was routed close to the cab underside to reduce heat).
The headers still run hot, but not as quite as hot as before (once I enriched the fuel/air mix with my Power Commander) to compensate for the header change.
Here's a photo of my headers before installation. This is the polished version. Note that where the temp is over 1300 degrees exiting the engine, the polished appearance will become flat.
Note that in the photos below, the black areas on the headers are reflections, not discoloration, as I had not put them on the bike yet.
Im having the same issue overheating
when you say burp...which cap are you removing til hot the resevoir or the radiator cap. Or could it possibly be my thermostat..PLEASE HELP:king:
Is there anything besides water wetter that will work just as good. I’m about to flush my coolant system and saw all the post about distilled water and water wetter and coolant. Just curious. Mine runs on the high side but it just started doing it. I bought my A1 in October 2018 (2000) and it never happened until a couple days ago
1 - 20 of 23 Posts
