1 - 9 of 9 Posts
This might be a stupid question but :headscratch: I've just bought a pair of K&N filters for the 12
I got these way cheaper than standard one's , I've just put them in and they will not fit the way they are suppost to.
I had to put them in backwards to what they reccomend. The filter has a front side but will not fit , Turned around 180 degs.they fit fine.
Has anyone else had a similar problem with these filters and will it affect air flow at all ?
First, G'day mate, another Adelaidian!!
The K&N's are notorious for bad fitting, just do a search in the Advanced Search box function top right corner of the site page!
I have them and in the proper way, BUT, I have used small amount of grease on the side walls of the filters to ease fitting. It is best to take a cover off the air box so you can see if the filter sides are sliding properly down the track grooves of the filter slots (if you know what I mean).
Just out of interest, if you have problems I may be able to assist with bits and pieces of info on the 12 if close by, just send me a personal message.
Don.
Don.
+1 , always grease the sides and bottom IMO ,it also stops debre from entering .
PS you will gain no HP from them if there oiled up ,I run mine with no oil but I guise (meaning guess ,im still learning) each to the own.:thumbup: lol)
Mine go in and out of the B2H with no problem.
They are greased around the perimeter both sides.
Don't throw the bushes out with the old filters, like I did once.
Lube it up and slide it in! :thumbup:
Don.
Cheers Don , I'll keep that in mind
I have greased them but not oiled them , Not a fan of that unless it's my my dirt bike , Thanks for the replys guys :thumbup:
Sliced a little off the bottom of the filter as per DRP's page and all good :thumbup:
Just taking that slice off made all the difference, Thanks the the help guys , Much appreciated :thumbup:
1 - 9 of 9 Posts
