1 - 10 of 10 Posts
Hoping someone can help. I know zx12s run hot and have issues with heating up but what mine is doing can’t be normal.
on a run at any speed the temp is fine, either half way or just below it, if I’m stopped in traffic for 30 seconds, it’s up into the red and boiling the coolant out the over flow.
iv done the follow checks
water pump working 100%
fans working
Rad, flushed and seems fine
Thermostat (haven’t checked because my hands aren’t that small, but if it’s running ok normally I’m thinking it’s working ok)
Bleed the system as while so there isn’t any air pockets
Bike isn’t pressurising, even at really high temp I can still squeeze the water pipes.
what im trying next, running water wetter and wiring one fan upto a switch I can control myself.
Anyone any other advice or ideas, thanks
You've got to replace the thermostat with an OEM unit. Could it be stuck slightly open? Weird the hoses arent pressurized... how did you measure water pump activity and flow?
Thanks for replying. The thermostat has been pointed out by a few people, although when it was removed it seems fine and working when I did the boiling water test. Although I have ordered an oem part.
Removing the old one wasn’t so nice though, one of the bolts snapped so I know have the engine removed to fix this.
16610
As for the water pump, as the bike was running so well normally I wasn’t too concerned about checking the flow, more concerned on the condition of the water pump, although I did remover the top hose from the pump and start the bike so I could watch the pump moving freely, even under throttle it was still spinning freely, so I was happy enough with it, without going much more in-depth.
my plan going forward is to fit a 40% more aluminium rad, new thermostat,use water wetter and wire one fan to a switch for manual control.
if this doesn’t cure the problem I will have to look more in-depth at the water pump
Switch to 100% engine ice. You will need 2 containers to fill from empty.
If the hoses are not obtaining pressure, it is 100% the thermostat. Temp is rising because it is stuck open. Yes, it's tight and you need to take your time, but it's much cheaper than replacing the whole engine from overheating. Use an OEM Kawasaki thermostat.
Also, look into a switch to turn the fan on when you hit heavy traffic.
GET A NEW RAD CAP
you already answered your own question, its not building pressure, it will boil at a lower temp.
Agreed. New radiator cap is the only thing not listed in the first post!
Did you figure it out? Cap does seem like a possible issue.
1 - 10 of 10 Posts
