Are there any parts that compatible from a ZX6R to an ZX9R? I have the green '03 and can hardly find anything but ZX6R's are fairly more common. Nobody wants to give up the 9. I am looking for an extra set of plastics and gas tank.
Thanks,
Jason
Compatible parts:
~valve shims
~petcock knobs
~rearview mirrors (they also fit on the EX500 too, BTW)
~front tires
~drive sprocket lock nuts and washers
~oil filler caps
~brake levers
~clutch levers
~passenger seats
~fairing screws and well-nuts
~rear axle nut and washer
~bar-end weights and screws
I happen to have a crunched '02 ZX6R tank in my garage now and an '02 ZX9R, and will check that for you if I get time. The plastics will not fit--completely different layour. If you bought an entire new fairing set, it ~might~ work, but my guess is probably not.
I was under the impression that the bodywork was very different since the 9 is so much wider than the 6. I wouldn't know about the tank.
The tank is MUCH wider on the 9. It's the easiest way to tell the two bikes apart.
