1 - 2 of 2 Posts
Hi all I have a problem with the low rev range below 3 it seems to bog down roll the throttle back and just open it its ok, now I'm running a yoshi cut down and I have the pilots out 2 turns
as the pilots work up to 4-4.52 I was thinking of turning them out to 2 1/2 turns ???
just wondering what you think
Any help would be appreciated
Shim the carb needles with .5mm washers from screwfix. Changing pilot settings will just get you a sooty pipe, these washers are tiny and I cant remember the part no. but they have approx 5mm opening which you'll have to slip onto the carb needles, this raises the needles slightly and smoothes out the low end running, you could also rejet the carbs but a packet of shims is about 50p last ones I bought so its a no brainer for me.
1 - 2 of 2 Posts
