Hi all I am the owner of a zx9r 1998 .
Few weeks ago I went on a awsome ride out on the bike doing some high speed and knee grinding. . I used the bike to work the following morning about 15 mile ride everything was spot on I worked my shift and when I came to go home the bike would not start :( . I traced it down to no spark at all . So I replaced the cdi unit and it started up and then I kept turning it off and on and it worked fine the following morning I have no spark again :(
Iv replaced the fuel pump relay and checked all the resistance of the coils bypassed the side stand switch and still no luck . Anyone have any ideas of what It could be ? .........
Any reply very much apreaciated :)
Check the usual stater regulator rectifier battery.... Then go over the wiring harness looking for exposed wires.... Sounds like wires touching?? Ur lucky not much electrical on that bike so happy hunting.
Check fuses and stuff... Iono good luck sir
Cheers lads at this point I have replaced the ignition the cdi unit the fuel pump relay tested the coils and current t to coils but still no spark at the plug :s iv got all the wiring open and can't find any defect with it its driveing me nuts �� battery is brand new iv tested the pick up risistance to the Haynes manual and comes back as it should . The bike will turn over as it should just no spark . Any more ideas? Haha Cuz I'm close to just leaving it out the front of the house for the scrappys ��
Just cleaned out the kill switch /starter button and clutch switch to . Still no joy haha this bike is testing me :( haha
Time to test the cam position sensor, it's attached to the outer side of the number one header pipe. it has a grey plug on top of the cam cover about 6 inches away. 460 Ohms if I remember right but check the book.
