Small hole bottom of Oil Pump - Kawasaki Forum :: KawasakiWorld.com
post #1 of 6 Old 12-27-2014, 08:15 PM Thread Starter
What we have here is a small very slow leak that is coming out of a small hole on the bottom of my oil pump on my 06 ZR750K or Z750S I believe same motors in each. Anyway anyone know about this hole and what its for? Should I plug it? replace the pump? rebuild it? Only leaks when it runs and it is very slow. If you don't know your oil pump its behind the water pump closer to the motor. Any help would be appreciated.
Thanks
Rollon is offline
post #2 of 6 Old 12-27-2014, 09:46 PM
hagrid's Avatar
Any chance for a photo?
Could be a bleed hole to prevent air lock after an oil change.
hagrid is offline
post #3 of 6 Old 12-28-2014, 12:03 PM Thread Starter
06 ZR750K Z750S Oil Pump-small hole on bottom
Tried to download picture have to see if it worked. The hole is in the brass colored peice between the black peices. This is the oil pump.
Rollon is offline
post #4 of 6 Old 12-28-2014, 07:19 PM
zx12mark's Avatar
Yepper Thats the weep hole for the water pump.Its telling you to replace it and the seals.No big job really.
2000 zx12r 65,500 mile( Now 6000 miles on 2003 brand new engine} street bike 9.6`s in the 1/4 a few times.My 2012 14r stole me away.8.9 swb stock engine Brocks bolt ons so far..Now my H2 piss`s on everything. H2 now Brocked out and I can`t control it. Oh well I tried.
zx12mark is offline
post #5 of 6 Old 12-28-2014, 07:43 PM
maxumis's Avatar
Photo's are a great thing .
maxumis is offline
post #6 of 6 Old 12-29-2014, 09:28 AM Thread Starter
Thanks guys. I ordered the oil pump seal and the water pump seal and the O rings that separate the housings for the pumps. Getting great circulation with oil and the water as well and they are keeping very separated. I guess thats what the weep hole is for - so anything getting through from one towards the other leaks out. Like a warning. Slow going here should have it done in a month.
All The Best
Rollon is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki Motorcycles > Z750 Z1000
Tags
oil leak, oil pump zr750k, z750s
Bottom End Rebuild 03GreenZx12 ZX-12R 7 11-12-2011 03:04 PM
Bottom end trauma fastone63 ZX-12R 16 09-09-2003 11:39 PM
Small hole in tire... Fix a flat, tire repair kit???? gtr zx12 ZX-12R 9 07-31-2003 12:56 PM
