HELP...rear brake <<CLUNKING>>! - Kawasaki Forum :: KawasakiWorld.com
post #1 of 6 Old 05-16-2004, 03:43 AM Thread Starter
Venumb's Avatar
<<CLUNK>>..that's the sound I was hearing whenever I applied my rear brake. I had my bike up on the stands yesterday and realised where the sound was coming from. The bracket that allows the rear brake caliper to slide foward and back during chain adjustments seems to have developed slop in it. When I apply the rear brake the entire caliper rotates foward about 1/16th of an inch. Has anyone else experienced this?
I just turned 6,000 miles on my bike and it seems kinda premature for this kind of wear. Any input you guys have on this is appreciated.
Venumb is offline
post #2 of 6 Old 05-16-2004, 04:53 AM
Moderator
EPSTEIN's Avatar
Send a message via AIM to EPSTEIN
Did you check to see if the rear caliper bracket may not be in the slot?....there is a slot and grove on the swingarm and bracket that have to inter lock inorder to prevent movement....Easy to miss during a tire change .....
Brian
"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." Albert Einstien
EPSTEIN is offline
post #3 of 6 Old 05-16-2004, 11:52 AM Thread Starter
Venumb's Avatar
Brian
Yeah it's sitting properly in the slot. My rear tire was off is over 2,000 miles ago and it just started clunking within the last 30-40 miles. Guess I'll tear it apart and see what I find.
Venumb is offline
post #4 of 6 Old 05-16-2004, 09:18 PM
tighten the axle nut
GreenMamba1 is offline
post #5 of 6 Old 05-17-2004, 04:49 AM
Send a message via AIM to Lou zx12r
Greenmamba1 is on to something, loosen up everything to do with the rear tire, check that all is in place and retighten everything back up. It could be that something has slipped out of place. Also the rear caliper is suppose to have a little movement just not to extreem. HAve a friend take a 2nd look if nothing stands out for you.
Lou zx12r is offline
post #6 of 6 Old 05-17-2004, 10:29 AM
ZX12richard's Avatar
I would also check that side wheel bearing... Brake side tends to go first.... Least on mine..
Bought a new medical alert bracelet. Says "Probably just shitfaced"
ZX12richard is offline
Front brake clunking and front wheel axle spacing DinoDanny ZX-12R 10 09-29-2013 02:01 PM
rear brake ????? ToolMaker12 ZX-12R 12 09-05-2010 06:50 PM
Rear brake mattwebb ZX-12R 2 08-19-2008 05:18 PM
Changed rear tire, now rear brake is gone? sandor ZX-12R 10 07-18-2006 05:30 PM
Rear Brake ZX-12R 20 10-11-2001 07:13 AM
