Fuel Injection Light - Kawasaki Forum :: KawasakiWorld.com
post #1 of 7 Old 10-29-2004, 07:32 PM Thread Starter
Sorry I did a few searches and didn't find anything. Had a problem happen to me twice today, here is the scenerio.
Started the 12, let it warm up til the temp moved off the coldest spot, took off, went to leave the next stop sign and nice and smooth take off then it just quit pulling like I had let off the throttle. I looked down the FI light was on, it did this for about 2-3 secs I never changed throttle position then it light went out and it pick up right where it had left off.. didn't do it again...............until...
about 2 hrs later different ride
same thing I took off went 2 miles stopped turned it off, got gas. . so this time it was completely warm.. started it up, pulled out of the gas station and bam.. it did it too me again same thing.
What concerns me if I wasn't expecting this in a slow intersection corner I could see me dumping it, it would almost be like hitting the brakes.
the bike has 14K miles on it, its a 2000 zx-12r, never had any trouble, and its bone stock.. I mean BONE stock.. stock plugs, air filters, can.. left everything factory.
Jethro12 is offline
post #2 of 7 Old 10-29-2004, 08:53 PM
It happens to me every now and then,
But mine is caused by doing long (a km or more) wheelie with less than half a tank of fuel.
The first time it did it it scared the crap out of me. (Ie on the back wheel and the bike just shuts down).
Hertz is offline
post #3 of 7 Old 10-29-2004, 08:57 PM
Could the TPS cause it or even a fuel pump? I used to have a car that died on me due to a broken wire (under the insullation). It would die and when I got it to the shop, vibration had gotten it back together again. Took like 15 times to find it. Finally found it by shaking wires in the shop until it died. :?
Zang is offline
post #4 of 7 Old 10-30-2004, 09:17 AM
Sounds like nothing is broken when it comes and goes. Check all connections. Everything from a watertemp sensor to TPS. And when having them loose. Put some grease (special, for electric connections) in them to be sure there's absolute connection there. Will most likely solve your problem. It's hard to find these problems, I know. But a sensor almost never starts to fail and then don't. Either it's broken or not!
Check your connections!!
Swede is offline
post #5 of 7 Old 10-30-2004, 11:49 AM
Has anyone checked to see if the fuel injection system (ECU) saved an error code? Not saying that it tells you everything, but it may give you some clues. :)
Whimp is offline
post #6 of 7 Old 10-30-2004, 11:51 AM
Whimp is offline
post #7 of 7 Old 10-30-2004, 02:57 PM Thread Starter
I took it too the track last night and it never did it too me..
It was my first time and I didn't do great, ok but not great..
here were the results
RT .474
60 2.014
1/4 10.889
mph 132.48
RT .259
60 2.052
1/4 10.978
MPH 132.41
RT .568
60 1.992
1/4 10.939
MPH 131.98
anyway.. Is getting the codes something I can do.. I have a service manual but I haven't looked yet.
Jethro12 is offline
Fuel injection light flashing at start XdtesZombie ZX-12R 8 12-13-2008 04:28 AM
Fuel Injection Indicator Light Blinking onebad ZX-12R 3 08-28-2006 04:07 PM
Fuel Injection Light coming on??? darrmo ZX-12R 1 01-06-2006 05:15 PM
fuel injection. 03-ZX9R ZX-9R 8 05-13-2005 11:08 PM
Fuel Injection Light - Intermittent fault 2000 zx12r a1 deggs ZX-12R 6 10-02-2003 08:37 AM
