Fuel Enricher Valve - Kawasaki Forum :: KawasakiWorld.com
post #1 of 5 Old 10-02-2001, 11:39 AM Thread Starter
I cannot notice any difference in rpm, cold starting or anything when I turn the enricher valve on. Before I start digging into this, what are you guys experiences? I.e: if the bike is warm and you hit the enricher, does it sputter and spit like a carburated bike with the choke on while warm?
This don't seem right to me....
I got a list of demands written on the palm of my hand...
Blitzkrieg is offline
post #2 of 5 Old 10-02-2001, 01:25 PM
I believe the toggle only increases your idle, that is it. It is not really a choke, but more of a fast idle.
With the fuel injection you don't need the choke. But I certainly need the fast idle when it is cold.
[email protected]
www.ZX-12R.org</font>
Top 100 Bike Sites</font></p>
[email protected]
www.taxstrategy.org
Fighting on the internet is like competing in the special Olympics, even if you win, you're still retarded ...... No offence to handicapped people. Remember to Click !
easyrider is offline
post #3 of 5 Old 10-02-2001, 01:31 PM Thread Starter
Well, granted things have been pretty warm here (lets say about 50 F last weekend when I fired it up), but I notice nothing in the way of increased idle speed when the lever is down. My suspicions are that the same guy that put on my front blinkers adjusted my enrichment switch.....
post #4 of 5 Old 10-03-2001, 09:48 PM
Hi Blitzkrieg,
Easy is right, if you activate the lever and look on the right side of the bike, where the throttle cables are attached to the 'Carbs' (air intake assemblies and injectors) you can see the throttle linkage accelerate. Basically what happens with injection engines when this is done is that as you accelerate, you open the butterflies on the air intakes, and the throttle position sensor (attached to the butterfly linkage on the left hand side of the bike), also turns ( adjusting the readout of the tps) which tells the little black box (engine management), to inject more fuel and adjust the timming.
That's more or less it.
regards GibZX12
Gibzx12 is offline
post #5 of 5 Old 10-03-2001, 09:57 PM
Hi,
I certainly notice a difference in RPM when I first start the bike on cold mornings, but the "choke" is only 1/2 on. Easy and gibzx12 are both right. By opening the throttle bodies and allowing more air in, the management system will sense that more fuel is required to sustain the engine from stalling and provides it,hence the slight increase in RPM. (unlike my previous 7's and 9's which scream up to 4,000 rpm or stall with little or no control between)!
Regards
Ted
Speed kills play safe and buy a Honda!
Ted Edwards is offline
Using a lot of oil/Valve job? marmstro ZX-12R 26 03-26-2011 04:09 PM
valve clearance scoutmanii74 ZX-12R 6 07-03-2010 12:27 AM
Advice for removing fuel tank and servicing fuel filter stube40 ZX-12R 4 09-23-2008 10:57 PM
valve adj on a 03 zx9 nolmt mp ZX-9R 10 06-25-2006 10:02 AM
leaded fuel and valve adj 12Kawzxr ZX-12R 13 04-05-2005 11:30 AM
