Need Help! Headlights not working - Kawasaki Forum :: KawasakiWorld.com
post #1 of 14 Old 07-25-2006, 09:40 PM Thread Starter
I have a 00 12. The other night I was leaving hooters and my headlights would not come on. All my fuses are good, I tried my friends junction box thinking it was it but it was'nt. Any ideas what it could be. I would appreciate any info.
bigpun51 is offline
post #2 of 14 Old 07-25-2006, 10:10 PM
Moderator
lie2me's Avatar
did you swap bulbs? sometimes its the simple stuff. I had super-white lights and they both shit the bed.
lie2me is offline
post #3 of 14 Old 07-25-2006, 11:05 PM
Send a message via Yahoo to ZXLNT
Dead stator, or possibly the headlight relay, or the headlight fuse that is in the battery box. Start with those ideas. Work it 1 thing at a time though.
ZXLNT is offline
post #4 of 14 Old 07-25-2006, 11:23 PM
GO 200's Avatar
Since your headlights failed to "come on", instead of failing under power, my vote is the headlight relay... I think there may be 2 relays in that circuit... 8) 8)
I can explain it to you, but I can't understand it for you.
GO 200 is offline
post #5 of 14 Old 07-26-2006, 12:19 AM
If all else fails, go back into Hooters! Plenty of headlights in there!
post #6 of 14 Old 07-26-2006, 04:14 AM
ZX12richard's Avatar
Both my plugs melted needing replacing I replace with car ones...
Bought a new medical alert bracelet. Says "Probably just shitfaced"
ZX12richard is offline
post #7 of 14 Old 07-26-2006, 05:07 AM
if you swapped with a good junction box. Unless you burnt the relay out of that JB as well.
- Matt
'02 ZX-12R
'05 Mini Chopper
Wideout is offline
post #8 of 14 Old 07-26-2006, 05:44 AM
Avenger's Avatar
Send a message via AIM to Avenger
There is a fuse in the battery box !!!! Mine did this a few yrs back and took me forever to figure it out.....have no clue why they would put a fuse there when all the others are under ur fake tank ????
Avenger is offline
post #9 of 14 Old 07-26-2006, 07:21 AM
Yep,a second headlight fuse. There's also a main fuse in there. :?
- Matt
'02 ZX-12R
'05 Mini Chopper
Wideout is offline
post #10 of 14 Old 07-27-2006, 08:57 AM
OutsiderZX12R's Avatar
Send a message via Yahoo to OutsiderZX12R
Excellent point! :twisted:
I hate stupid people.
OutsiderZX12R is online now
post #11 of 14 Old 07-27-2006, 09:58 PM Thread Starter
No luck. Tried both relays and the headlight fuse in the battery box. My headlights are not blown. I wonder if the high beam low beam switch could trigger any of this.
bigpun51 is offline
post #12 of 14 Old 07-27-2006, 10:11 PM
You did check the headlight fuse in the fuse box under the tank cover on top of the airbox right??
ZXLNT is offline
post #13 of 14 Old 07-28-2006, 05:08 AM
"Tried both relays", not sure what you mean by that.
I think he did ZX. Your next step (if you're electrically inclined) is to bypass the relay in the junction box. You'll need the wiring schematics from a shop manual...
Doubtful that the switch is the culprit.
- Matt
'02 ZX-12R
'05 Mini Chopper
Wideout is offline
post #14 of 14 Old 07-28-2006, 08:17 PM
He's probably talking about the high and low beam relays in the upper fairing.
Dan
oldkawboy is offline
2006 zx14 headlights not working please help seionkelley ZX-14 1 10-27-2011 05:53 AM
headlights KZScott ZX-12R 17 12-01-2009 09:40 AM
Fans & Headlights Not Working Grantkt ZX-12R 0 02-10-2007 05:46 PM
Headlights not working.....fack. shiphteey ZX-12R 4 09-25-2006 04:48 AM
Headlights Paul Sonderfan ZX-10R 7 05-29-2004 10:57 PM
