Kawasaki Forum :: KawasakiWorld.com (https://www.kawasakiworld.com/forums.php)
-   ZX-12R (https://www.kawasakiworld.com/zx-12r/)
-   -   Fuel injection light flashing at start (https://www.kawasakiworld.com/zx-12r/36654-fuel-injection-light-flashing-start.html)
XdtesZombie 12-08-2008 04:10 PM
My bike has seemed to develop a new behavior.Every once in awhile when I try to start it it just cranks over and wont fire,and while cranking the fi light is flashing.When I shut of key and turn it back on it starts or does this again but after another on off cycle will start and runs fine.I had a full service not too long ago and just installed k&n filters and a yoshimira rs-3 bolt on.Other than that its a stock 2001 no pc3.Anyone have any ideas?
Mauser 12-09-2008 12:06 AM
Anything on this link worth trying ?.
FI light, hard starting and stalling @ ZX12R ZONE.com
jeremy_kokwk 12-09-2008 03:24 AM
is your PC3 linked to your brake switch? if so it is better to reconnect the wire to other power source.
Power Commander Support F.A.Qs
XdtesZombie 12-09-2008 07:45 PM
I dont have a power commander and I read that other thread but it doesnt seem to apply.
indy12RR 12-10-2008 11:04 AM
Dont know if it helps, but I had an Air Pressure Sensor that was going out on my 12. Anytime I would get hard on the throttle for more than 5 minutes, she would stall out next time I came to a stop. Try to find someone with a shop manual, that way you can pull the code out and see what your flashing FI light is for
Sil
Indy12RR
lgm118icbm 12-12-2008 10:28 AM
is your fuel pump cycling on when you are having this problem?
You should be able to hear it when you switch the key.
My fuel pump relay has been acting up recently.
XdtesZombie 12-12-2008 08:27 PM
I am not sure does it make a constant noise or just a short noise?
shiggsy 12-13-2008 03:18 AM
It should be a 3 second whirring noise and should be easy to hear.
The flashing FI light means you have a current fault code, this link should help you determine what it is.
https://kawasakiworld.com/kawasaki-zx...ounds-bad.html
KZScott 12-13-2008 04:28 AM
tell us the fault code and someone with a manual (i can do it) will look up your problem
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright 1999 - 2010 Kawasaki World. All rights reserved. KawasakiWorld.com is a Kawasaki Forum for Kawasaki Motorcycles. We are run by enthusiasts for enthusiasts. We are not affiliated with Kawasaki USA.
