Fuel injection light flashing at start - Kawasaki Forum :: KawasakiWorld.com
post #1 of 9 Old 12-08-2008, 03:10 PM Thread Starter
My bike has seemed to develop a new behavior.Every once in awhile when I try to start it it just cranks over and wont fire,and while cranking the fi light is flashing.When I shut of key and turn it back on it starts or does this again but after another on off cycle will start and runs fine.I had a full service not too long ago and just installed k&n filters and a yoshimira rs-3 bolt on.Other than that its a stock 2001 no pc3.Anyone have any ideas?
XdtesZombie is offline
post #2 of 9 Old 12-08-2008, 11:06 PM
Mauser's Avatar
Anything on this link worth trying ?.
FI light, hard starting and stalling @ ZX12R ZONE.com
Mauser is offline
post #3 of 9 Old 12-09-2008, 02:24 AM
Send a message via MSN to jeremy_kokwk
is your PC3 linked to your brake switch? if so it is better to reconnect the wire to other power source.
Power Commander Support F.A.Qs
jeremy_kokwk is offline
post #4 of 9 Old 12-09-2008, 06:45 PM Thread Starter
I dont have a power commander and I read that other thread but it doesnt seem to apply.
post #5 of 9 Old 12-10-2008, 10:04 AM
Member
indy12RR's Avatar
Dont know if it helps, but I had an Air Pressure Sensor that was going out on my 12. Anytime I would get hard on the throttle for more than 5 minutes, she would stall out next time I came to a stop. Try to find someone with a shop manual, that way you can pull the code out and see what your flashing FI light is for
Sil
Indy12RR
indy12RR is offline
post #6 of 9 Old 12-12-2008, 09:28 AM
Send a message via AIM to lgm118icbm
is your fuel pump cycling on when you are having this problem?
You should be able to hear it when you switch the key.
My fuel pump relay has been acting up recently.
Irvine, Ca
03 ZX-12R
03 Z1000sc
03 ZX-6R
98 Concours
lgm118icbm is offline
post #7 of 9 Old 12-12-2008, 07:27 PM Thread Starter
I am not sure does it make a constant noise or just a short noise?
post #8 of 9 Old 12-13-2008, 02:18 AM
shiggsy's Avatar
It should be a 3 second whirring noise and should be easy to hear.
The flashing FI light means you have a current fault code, this link should help you determine what it is.
https://kawasakiworld.com/kawasaki-zx...ounds-bad.html
hung like Einstein, smart as a horse
shiggsy is offline
post #9 of 9 Old 12-13-2008, 03:28 AM
KZScott's Avatar
tell us the fault code and someone with a manual (i can do it) will look up your problem
KZScott is offline
FI light flashing roczilla ZX-12R 13 07-11-2011 03:04 AM
Fuel Injection Indicator Light Blinking onebad ZX-12R 3 08-28-2006 03:07 PM
Fuel Injection Light coming on??? darrmo ZX-12R 1 01-06-2006 04:15 PM
Fuel Injection Light Jethro12 ZX-12R 6 10-30-2004 01:57 PM
Fuel Injection Light - Intermittent fault 2000 zx12r a1 deggs ZX-12R 6 10-02-2003 07:37 AM
