FI light on.. - Kawasaki Forum :: KawasakiWorld.com
post #1 of 10 Old 03-30-2010, 01:47 PM Thread Starter
rfc
FI light on..
hello all,
im new so be easy....
i do not have the manual yet.
2000 zx12 with a 02 engine in it (ecu was not transferred).
battery was dead and when started it FI light was on steady.
no loss of power no hesitating.
any ideas?
could it be related to a weak battery?
is there a difference between 00 and 02 ecu?
i was trying to search but couldn't see anything similar.
thank you
ron
rfc is offline
post #2 of 10 Old 03-30-2010, 07:40 PM
XENO's Avatar
it have a pc3 on it?
XENO is offline
post #3 of 10 Old 03-30-2010, 09:33 PM Thread Starter
rfc
no pcIII and no mods
ron
rfc is offline
post #4 of 10 Old 03-30-2010, 10:25 PM
XENO's Avatar
i would messege kzscott and ask him about it alot of guys on here with knollege on the 12r here just he comes to mind he has helped me alot in the past sure he could help u also
my fi light came on while i was out on my 12r was after i put this undertail on when i did i had to relocate the ecu and stick it in the trunk with my pc3 when the fi light came on the motor shutdown come to find out the one of the ecu plugs had come unplugged guess i didnt have it locked in good might check the ecu but if its running fine i wouldnt think its that like i said PM kzscott he could help u alot more then me
XENO is offline
post #5 of 10 Old 03-30-2010, 10:32 PM
uffigang's Avatar
the FI light is always on ??
or is the FI light flashing ? if yes how often is the light flashing ?
Free workshop manual download for Kawasaki ZX12R Ninja (ZX1200 A)
woppi - 1st TFA Member / Austria !
" if it has wheels or titts - sometimes you will get troubles "
uffigang is offline
post #6 of 10 Old 03-30-2010, 10:43 PM
vladutz's Avatar
Send a message via Yahoo to vladutz
get the manual and see pages 95-101 (from point 4-49). It has a self diagnosis mode. Maybe I'll find out what the problem is.
And yes, I think that is a diference between 00 and 02 ecu but I don't think that it should not be a problem.
It's not battery related. The FI light is only for Fuel Injection problems....but you said that the battery was dead. Did you get power from another battery (car) to get it started?
ZX 12R, 2000, yoshimura rs3 full system, PC3
vladutz is offline
post #7 of 10 Old 04-01-2010, 02:01 AM Thread Starter
rfc
thank you all so far.
the i jumped the battery to start.
the FI is constantly on no flashes.
rfc is offline
post #8 of 10 Old 04-01-2010, 04:48 AM
shiggsy's Avatar
If the FI light is on it means there is a fault code present.
Instruction to retreive the fault codes are in this thread:
https://kawasakiworld.com/zx-12r/3385...ounds-bad.html
hung like Einstein, smart as a horse
shiggsy is offline
post #9 of 10 Old 04-03-2010, 11:19 AM Thread Starter
rfc
ok,
thanks for the link. i have already used it.
i came with code 15 (went through the pages as well).
however, 2 q.
1. this not the first time this sensor gave that problem (i spoke with the PO).
what can be the cause?is it common?
2. what are the risks (if it backed up by the ECM at a static pressure)
thank you
ron
rfc is offline
post #10 of 10 Old 04-03-2010, 01:28 PM
shiggsy's Avatar
Originally Posted by rfc View Post
ok,
however, 2 q.
thank you
ron
Its either the sensor or the wiring to the sensor. There is an identical sensor on the throttle bodies, so you could swap them over and see if the fault follows the sensor. They are not very expensive though. Its not that common a problem.
shiggsy is offline
GREEN LIGHT Stop Light Trigger bldragon General Discussion 5 05-22-2011 01:45 PM
L.E.D light help.. Santry426 ZX-12R 3 12-23-2007 05:41 PM
FI light on, neutral light not on hillrest ZX-12R 1 07-05-2007 12:02 AM
help! oil light on wales ZX-12R 11 11-21-2004 07:40 PM
fi light on HELP HELP!!!!!!!!!!!!!!!!! bl12r ZX-12R 14 08-13-2003 03:33 PM
