Engine won't start!!! - Kawasaki Forum :: KawasakiWorld.com
post #1 of 26 Old 05-14-2013, 12:19 PM Thread Starter
Hi all, I have a very strange problem and hopefully someone have the answer.
My engine just won't start, I have checked everything I know of. I have spark and I have fuel, I have measured all my sensors and checked the cam chain position and its all ok. The engine fire on all cylinders, or at least get worm on the exhaust pipes, but it just won't start not even with start gas. It's just like the cam chain is a few tooth wrong or the timing is way off but I have checked it all.
Chrilla is offline
post #2 of 26 Old 05-14-2013, 12:30 PM
Mrmo's Avatar
Can you hear the fuel pump prime as you switch the bike on?
Mrmo is offline
post #3 of 26 Old 05-14-2013, 12:38 PM Thread Starter
Japp, it primes and pumps when I crank it. I even looked down the trumpets and checked the injectors, and there's a nice fog of fuel each stroke.
Chrilla is offline
post #4 of 26 Old 05-14-2013, 12:38 PM
Mrmo's Avatar
My thoughts would be:
Check fuel pump is working
Check neutral light is on
Check plugs for any fouling not just spark
Battery charged enough to turn over but not enough to start
Unplug and plug back in tps
Mrmo is offline
post #5 of 26 Old 05-14-2013, 12:42 PM
SHEP's Avatar
If it is not turning over, try leaving the clutch lever out!
The clutch switch is renown for sticking in the wrong state and only allowing the engine to start when out rather than in.
If that's it, strip it, clean it and all will be well again.
If at first you don't succeed....take a longer run up!!
SHEP is offline
post #6 of 26 Old 05-14-2013, 01:00 PM Thread Starter
Haven't tried with clutch out actually but the rest is all ok, new battery, new spark plugs and pump works and I have checked the fuel pressure. But sense I have spark and it fires and shoots nice fireballs out the exhaust, I just can't understand why it won't start.
Chrilla is offline
post #7 of 26 Old 05-14-2013, 01:04 PM
SHEP's Avatar
It's not the clutch switch then, that kills it totally.
SHEP is offline
post #8 of 26 Old 05-14-2013, 01:22 PM
SHEP's Avatar
Is the FI light flashing or giving you any codes?
Have you disturbed the tilt sensor (on rear subframe, right side)?
SHEP is offline
post #9 of 26 Old 05-14-2013, 01:56 PM Thread Starter
The Fl don't show anything but I think the tilt sensor have bin on because I bought a crashed bike and have changed and fixed everything that was bad, even the hole electrical wiring is new except for the battery box and all in it.
Chrilla is offline
post #10 of 26 Old 05-14-2013, 01:57 PM
Mrmo's Avatar
I just thought tilt sensor too, possibly and air flow problem? Either that or an electrical fault not allowing enough power to get start up rpm?
Mrmo is offline
post #11 of 26 Old 05-14-2013, 02:01 PM
engineerrol's Avatar
Whoooaaaaa now. It's shooting fireballs out the exhaust?
engineerrol is offline
post #12 of 26 Old 05-14-2013, 02:27 PM
my12r's Avatar
Timing.
T. J. Maiden ca. 1994
my12r is offline
post #13 of 26 Old 05-14-2013, 02:56 PM
rundog's Avatar
How long since the bike last ran? Have you done anything to it since then? How was it running?
rundog is offline
post #14 of 26 Old 05-14-2013, 08:41 PM Thread Starter
Well I exaggerated a bit about the fireballs, it's more like a little puff. And the timing was my first guess to but sense the timing can't be changed that leaves the cams, but they line up perfect against the crankshaft.
Chrilla is offline
post #15 of 26 Old 05-14-2013, 08:44 PM
Lets try this again...
1) has it run before?
2) if it has run before, what did you change?
3) if you changed something, did you mess that thing up?
difference between 00-04 engines? engine wont start hobster ZX-12R 21 09-08-2011 06:09 AM
hard start/no start ZX12Hef ZX-12R 9 10-21-2007 01:01 AM
Difference European engine and American engine gebla ZX-12R 10 07-20-2006 10:02 PM
Can't get used engine to start ((NEED HELP)) DoTsTeR ZX-12R 6 08-20-2004 04:41 PM
failed start at very hot engine msozzo ZX-12R 7 09-29-2003 08:45 AM
