Need a little help with my Clutch Problem - Kawasaki Forum :: KawasakiWorld.com
 3Likes
post #1 of 22 Old 09-03-2017, 03:43 PM Thread Starter
nohto's Avatar
Garage
Send a message via MSN to nohto
I have a 2000 ZX12 with approx. 17,000 fairly easy miles on the clutch. The dealership drilled my basket when it was new.
The problem I was having is the clutch was not disengaging all the way, making it hard to get into neutral, and also trying to creep forward while in gear.
I removed the clutch cover, steels, and fibers. Everything looked good, and both were with in specs. The stack was 57.8 on the bench, no warped fibers or steels.
The only thing that looks funky is the 2nd pic of the scratches.
Any ideas?
nohto is offline
post #2 of 22 Old 09-03-2017, 06:04 PM
smiffy's Avatar
Garage
Hi nohto. to be honest all the pictures look normal to me. (the marks on the clutch basket are just machine marks , they all have them)
All I can think of is cable adjustment.
Good luck.
There's nothing wrong with a extra wheel. A1 Model year 2000
smiffy is offline
post #3 of 22 Old 09-03-2017, 07:55 PM Thread Starter
nohto's Avatar
Garage
What's weird, is that after 17,000 miles, it appears that my stack is actually over the max spec. I added 2 2.0 steels (in place of 2 1.6) at first, thinking that I had to be under the spec, and when I tested it, the problem was worse than originally.
For me to get my lever free play, I have to adjust the lower adjustment almost maxed out, and the upper close to max also. (That was with the 2.0 steels)
nohto is offline
post #4 of 22 Old 09-04-2017, 11:19 AM
smiffy's Avatar
Garage
Yeah they are very touchy on the height, I'd try again & try & get the stack height at 57.4mm well above min, but just under max.
Good luck.
smiffy is offline
post #5 of 22 Old 09-04-2017, 06:38 PM
KZScott's Avatar
what oil are you running?
KZScott is offline
post #6 of 22 Old 09-04-2017, 09:19 PM Thread Starter
nohto's Avatar
Garage
Mobile One Racing 4T.
I used to run Motul E-Tech 100 for ever. I can't remember exactly when I switched to Mobile, but do you think that might be causing a problem?
nohto is offline
post #7 of 22 Old 09-04-2017, 09:21 PM Thread Starter
nohto's Avatar
Garage
Good luck.
Is that bench measured, not on the bike torqued? Don't know if it measures differently compressed or not.
nohto is offline
post #8 of 22 Old 09-05-2017, 09:57 AM
smiffy's Avatar
Garage
Bench mate.
smiffy is offline
post #9 of 22 Old 09-05-2017, 01:55 PM Thread Starter
nohto's Avatar
Garage
I have to take her apart again and I will try and get the height as close as possible.
KZ, any thoughts on the oil?
nohto is offline
post #10 of 22 Old 09-06-2017, 01:45 AM Thread Starter
nohto's Avatar
Garage
Checked my stack height with all original steels and fibers, and it is 57.9 mm. None of my steels or fibers are out of spec, but they must be warped just enough to exceed the max. height.
I know my steels are fine because I measured them separately and it came out exactly 17.6 mm.
Will .3 mm actually cause the clutch to not disengage properly?
I never changed my lower cable adjustment, because it would of caused there to not be enough free play if I remember correctly.
This is pissing me off. My dirt bikes never cause me any grief as far as the clutches go, and I hammer the shit out of them.
nohto is offline
post #11 of 22 Old 09-06-2017, 06:51 AM
smiffy's Avatar
Garage
Yes, sorry they are really critical on the clutch. I've had Suzuki's before & you could just chuck the clutch in & it would work. Not these though. They either work or they don't!
smiffy is offline
post #12 of 22 Old 09-08-2017, 02:19 PM Thread Starter
nohto's Avatar
Garage
Well, I have 2 2.0mm steels and the OEM 1.6mm steels. How would you recommend to get the height to spec?
nohto is offline
post #13 of 22 Old 09-08-2017, 02:36 PM
At about the same miles that's the same way I had mine done. But I don't remember, i either measured on the bike or I used clamps on the bench. I"m at 23k or so with the original plates, frictions and it's running fine. Unless the clutch has seen a hard enough life to causing warping I'd recheck the linkage and make sure there's good action.
Also go over the chain. besides the normal tension trying soaking it with lube and see if it makes a difference. i don't know if it'll work but nothing to lose.
olajoe808 is offline
post #14 of 22 Old 09-08-2017, 02:47 PM
Ok I'm pretty sure I had everything off, assembled and torqued to spec. I know I have written down somewhere.
post #15 of 22 Old 09-08-2017, 03:07 PM Thread Starter
nohto's Avatar
Garage
No, I have 2 new 2.0 steels not installed at this time. With all OEM parts I am over by .3mm. I actually increased height at 17,000 miles causing the clutch to not disengage entirely and making it difficult to find neutral.
nohto is offline
Stalling with clutch engagement kaboom ZX-9R 4 08-26-2017 05:36 PM
ZX 12R Clutch using a ZX14 Clutch? Vincent Hill ZX-12R 25 05-11-2017 12:54 PM
KX125 -87 clutch issue AntonLn Off Road 0 04-30-2017 07:50 AM
Zx12r clutch michael phillips ZX-12R 9 10-31-2016 12:36 PM
clutch slipping in 1st gear 2015 zx-6r nightsta1ker ZX-6R 2 08-28-2016 04:36 PM
