2000 zx12r trans parts - Kawasaki Forum :: KawasakiWorld.com
 1Likes
  • 1 Post By smiffy
post #1 of 10 Old 09-27-2017, 02:40 AM Thread Starter
Jgerardi1989's Avatar
Ok guys as per my last topic still dealing with the second gear issue. Dosent go into a false neautral just skips 2 or 3 times around 5-6k rpms. Im looking for some direction if i should just order whatever gears or the whole assy. I changed the whole assy a couple mnths ago (ebay) including drum and forks. If someone has already done this or can give me a link or drawing on what gears need to be changed it would be greatly appreciated
Jgerardi1989 is offline
post #2 of 10 Old 09-27-2017, 05:21 PM
KZScott's Avatar
you likely have worn engagement dogs (easy to see and fixed with a back cut), probably worn forks, and maybe bent shift shafts.
KZScott is offline
post #3 of 10 Old 09-28-2017, 06:12 PM Thread Starter
Ya thats kind of what i figured im just not 100%sure on what gears to change....
post #4 of 10 Old 09-28-2017, 07:05 PM
KZScott's Avatar
post pics
KZScott is offline
post #5 of 10 Old 09-30-2017, 09:46 PM Thread Starter
I would kzscott but its not apart yet. I dont want to do all the work again untill i know what parts to order. On the last one the gears looked gun but the forks did hhave wear to them nd the dogs were not rounded off but the edges were a lil bit mushroomed. But i thought second gear input/output were gears only
post #6 of 10 Old 10-01-2017, 07:06 AM
smiffy's Avatar
Garage
Lightbulb
Just a thought, it could be your clutch basket on its way out if you have already done the box ?
My mate had some thing similar & that turned out to be the basket springs had gone weak!
There's nothing wrong with a extra wheel. A1 Model year 2000
smiffy is offline
post #7 of 10 Old 10-01-2017, 01:24 PM Thread Starter
Hmmmmm very interesting smiffy. Nothing jumped out on me when i was inspecting the basket other then 2 hairline cracks in it where someone tried holding it with a prybar or screwdriver or something of that sort.
post #8 of 10 Old 10-02-2017, 09:08 AM
Everything you are describing is what im going through i will taking the bottom half off in a week to get back cut
BigSkip765 is offline
post #9 of 10 Old 10-02-2017, 11:07 AM
smiffy's Avatar
Garage
Question
Well, seeing as you have to take the basket off to get at the gears, when you put the "special" tool in to hold the starter gear to line up with the basket gear, (I use a 4mm allen key)
If you pull the tool out of the basket when its off the bike & the gears still line up , or you can move them with your hands, then I think it might just be the springs might be broke or weak, see if you can hear them rattling about.
Good luck.
olajoe808 likes this.
smiffy is offline
post #10 of 10 Old 12-03-2019, 08:00 AM
Originally Posted by KZScott View Post
post pics
She doesn't have any.
olajoe808 is offline
2000 zx12r trans Jgerardi1989 ZX-12R 3 09-04-2017 07:36 PM
2000 zx12r and 2014r oem parts for sale zx12mark Classifieds 4 04-30-2017 11:13 PM
2000 zx12r missing ECU question stone454 ZX-12R 3 04-01-2017 05:06 PM
2000 ZX12R - Electrical Gremlins (maybe ECU) SuperHoon ZX-12R 1 12-19-2016 07:21 AM
ZX12R Aftermarket Parts. UK only. Corbin, R&G, ASV, Givi etc llekra Classifieds 2 11-08-2016 01:26 PM
