Idle problems when warm - Kawasaki Forum :: KawasakiWorld.com
post #1 of 10 Old 09-15-2018, 10:26 PM Thread Starter
My bike has an unstable idle when it warms up, from a cold start its a stable 1000/1100 but when the engine is at operating temperature its continually rising and falling between 1500/900, any ideas what it could be?
Cal Thorsen is offline
post #2 of 10 Old 09-15-2018, 10:27 PM Thread Starter
2001 model
post #3 of 10 Old 09-16-2018, 01:42 AM
dastardly's Avatar
hi you could check your TPS Craig
no longer a rider but still an enthusiast
dastardly is offline
post #4 of 10 Old 09-16-2018, 01:04 PM Thread Starter
Would the TPS not affect the idle when cold aswell as hot?
post #5 of 10 Old 09-18-2018, 01:20 AM
dastardly's Avatar
yeah your probably correct just a thought
post #6 of 10 Old 09-18-2018, 10:47 AM Thread Starter
Someone told me it might be running rich, and that I have no problems when cold because it acts as a sort of choke but when warm will have to much fuel running, there could be something in that as my bike is running colder than normal, normally it would run with the temperature half way but now it raises only to one third.... Whats your thoughts on that theory dastardly?
post #7 of 10 Old 09-18-2018, 11:31 AM
Are the air cleaners clean?
Does it have a power commander?
Did you change anything in the map?
When was the last time you put a set of spark plugs in it?
color me gone is offline
post #8 of 10 Old 09-18-2018, 02:46 PM Thread Starter
It’s clean, there’s a PCV in, nothing in the map has changed, spark plugs are a few month old
post #9 of 10 Old 09-18-2018, 02:49 PM
KZScott's Avatar
post a video
KZScott is online now
post #10 of 10 Old 06-30-2019, 04:37 AM Thread Starter
Its was the tps, it had to be adjusted because of the open exhaust system, now purrs like a cat 👍🏻
cold start problems dastardly ZX-12R 26 05-20-2018 01:43 AM
ZRX1100C Unstable Idle MavericksGarage General Discussion 0 11-22-2017 12:09 PM
wont idle wes General Discussion 3 08-14-2017 01:31 AM
Throttle stumble/rough idle Donatello ZX-6R 0 08-10-2016 05:00 PM
cold start problems dastardly ZX-12R 1 08-06-2016 12:13 AM
