Power loss 7500-8000 rpms - Kawasaki Forum :: KawasakiWorld.com
 1Likes
post #1 of 26 Old 09-21-2018, 10:24 AM Thread Starter
Hi guys,
I have noticed loss of power in these rpms and then goes up to 10,000 rpms without energy. Has mounted BMC air filters and a Yoshimura exhaust, but with the stock filters I noticed the same failure... Anyone with similar problem?
Thank you.
TheMachine12R is offline
post #2 of 26 Old 09-21-2018, 02:54 PM
KZScott's Avatar
is it better at 10 or is everything up high down on power?
KZScott is online now
post #3 of 26 Old 09-21-2018, 03:16 PM
Mauser's Avatar
Fuel pump ?, remember similar faults in the past being down to this ?
*** ZX12-R ~ RT2 360 ~ XR650R ~ DT175MX ***
Mauser is online now
post #4 of 26 Old 09-21-2018, 03:21 PM Thread Starter
Hi KZ,
The motor is pushing with power till 7500-8000 rpms. Then loses power and is pushing till 10000 rpms like a motorbike with 100 HP.
The acceleration is great but at around that range turns like on-off whith power loss.
Sorry but maybe my english is not good enough to give you an idea of ​​the failure. Sometimes I do not know if my words are expressing what I want to tell.
Thanks for your help.
post #5 of 26 Old 09-21-2018, 03:24 PM Thread Starter
Hi Mauser,
But only on that range? Why not that fault at medium range rpms if the fuel pump is not working properly?
Thank you.
post #6 of 26 Old 09-21-2018, 11:48 PM
dastardly's Avatar
fuel filter in pump housing good luck Craig
no longer a rider but still an enthusiast
dastardly is offline
post #7 of 26 Old 09-22-2018, 12:44 AM
dastardly's Avatar
when the filter is blocked the bike hits a wall at about 8k rpm what year and mod is your 12
post #8 of 26 Old 09-22-2018, 02:55 AM Thread Starter
It is a 2005 model. Last one. Maybe you are right dastarly. I will comment to the dealership and hope they give me a solution.
Thanks.
post #9 of 26 Old 09-22-2018, 03:16 AM
SteveW's Avatar
Thanks.
The filter can be bought separately through Suzuki for a Hayabusa, whereas Kawasaki sell the whole assembly which costs a fair bit..
2006 ZX-12R B6F
SteveW is offline
post #10 of 26 Old 09-22-2018, 03:25 AM Thread Starter
Ok.
Thank you Steve.
post #11 of 26 Old 09-22-2018, 04:44 AM
dastardly's Avatar
I don't think so, the filter in that year mod is inside the pump housing not like the A mods you need to research and cut out the filter and add new inline filter don't bother pulling it apart and flushing the filter out it won't work 1st picture is A mod filter pump you can see the filter on the top right easy to replace the picture on the right hand side is B mod's that long plastic housing at the back the filter is inside there and not a replaceable part Good luck
post #12 of 26 Old 09-22-2018, 05:24 AM
KZScott's Avatar
i agree, it sounds like a plugged filter. try taking the assembly apart and flushing the filter backwards to get the gunk out
post #13 of 26 Old 09-22-2018, 05:47 AM Thread Starter
So guys,
Do you think I am going to be able to give solution dismantling the pump and cleaning it with air?
Thanks
post #14 of 26 Old 09-22-2018, 12:12 PM
KZScott's Avatar
it will be the filter not the pump, but thats basically what i said to do. btw not the pre filter sock, the filter in the housing
post #15 of 26 Old 09-22-2018, 01:50 PM Thread Starter
Maybe is this what we are talking about?
