Rear brake issue - locked up after first ride - Kawasaki Forum :: KawasakiWorld.com
post #1 of 8 Old 04-07-2019, 10:09 AM Thread Starter
Member
71Rcode's Avatar
Thanks in advance for the sleuthing on this. On my first ride after purchasing, the rear brakes went away after i used a couple times. Got home and realized the rear caliper was destroyed, with the pistons coming out of the bores and grinding away at the disk. I picked up a used caliper, cleaned her up and polished up the pistons, installing a nice used disk and a set of HHH sintered pads. Bled the rear braking system before my second ride today.
Rode about 5 miles, breaking in the rear pads. They felt great. However, I felt the bike laboring when I was about 1/4 mile from the house, so I slowed to a stop. The rear brake caliper was clamped down hard, the rear brake pedal almost in a locked (down) position. I was able to release a little tension on the rear caliper/disk and limped home.
What's odd is when I let the bike sit for 15 minutes, the rear brake pedal begin operating like it should, and the rear caliper is no longer clamped down on the disk.
Could the rear master cylinder be the culprit? Do I need to rebuild it? What you you guys recommend? Thanks much.
2000 ZX12R (A1) with 14k (Candy Persimmon Red)
71Rcode is offline
post #2 of 8 Old 04-07-2019, 12:20 PM
ninjayorkie's Avatar
Garage
Is the rear foot brake lever pivot free, it may need stripping and cleaning.
ninjayorkie is offline
post #3 of 8 Old 04-08-2019, 06:30 AM
jhinderliter's Avatar
That or the piston needs cleaned up..
Originally Posted by my12r View Post
He wishes he woulda thought of the green LED's first. He wishes he had balls big enough to ride without a helmet.
jhinderliter is offline
post #4 of 8 Old 04-08-2019, 06:51 AM
I would go for a full strip down . Had to do my fronts as they were seased up when I bought it .
filo is offline
post #5 of 8 Old 04-09-2019, 03:16 PM Thread Starter
Member
71Rcode's Avatar
Hey thanks guys for all the recommendations. I got the master cylinder and the rear caliper kits coming and will rebuild them this weekend. I can't afford to eat another rear caliper and disc too much downtime!I'll report back soon.
71Rcode is offline
post #6 of 8 Old 04-09-2019, 06:01 PM Thread Starter
Member
71Rcode's Avatar
Few pix of the first brake failure
71Rcode is offline
post #7 of 8 Old 04-09-2019, 06:10 PM Thread Starter
Member
71Rcode's Avatar
After reworking - and prior to the rear caliper locking up a second time. Now it's time to disassemble the rear caliper again and master cylinder and rebuild them both, and also checking the lube on rear brake pedal pivot.
71Rcode is offline
post #8 of 8 Old 04-21-2019, 04:40 PM Thread Starter
Member
71Rcode's Avatar
Just to close this thread for anyone who finds it. I found the issue which was a clogged return port in the master cylinder that wasn't allowing fluid to return to the master cylinder. To get to this, remove the 90 degree plastic pipe from the master cylinder by removing the circlip holding in place. I used a .010 high E guitar string to clean out the port along with brake cleaner and a toothbrush and compressed air. Good as new.
71Rcode is offline
98 zx6r rear brake problem zaden ZX-6R 1 04-14-2019 11:31 AM
Rear Brake Pad Retaining Clips chris555k ZX-12R 4 06-13-2018 02:56 AM
Rear brake Savagerider ZX-12R 0 09-17-2016 10:17 AM
Wanted rear brake caliper Savagerider Classifieds 1 09-07-2016 01:17 PM
Fitting Rear shock ride height spacer Tooloudman ZX-12R 10 08-29-2016 11:35 PM
