Loss of power and valve tapping - Kawasaki Forum :: KawasakiWorld.com
 1Likes
post #1 of 35 Old 05-27-2019, 04:36 PM Thread Starter
I'm new to the forum and I tried doing a search but looked through 2 pages of search results and I couldn't find specifically what I was looking for. My bike is a 2000 ZX-12 with 54K miles.
I was driving to work a couple weeks ago at about 6K RPM when all of a sudden the bike sputtered and began making a tapping noise. I pulled over and it died but I was able to restart and limp the 5 miles back home under reduced power. It won't idle anymore unless I keep the rpm's high and the tapping is synced with engine speed. It's been parked since this happened.
I checked the valves today and 4 of them are out-of-spec...all on the exhaust side and all too tight. I did a valve adjustment about 20K miles ago so that's why most are still in alignment now. 3 of the out-of-spec ones are only off by one shim size but the 4th has zero clearance.
Is there a chance that the tapping I'm hearing is coming from the piston hitting that 4th valve? Is the valve opening too far and hitting the piston? It's cylinder number one.
Rep94401 is offline
post #2 of 35 Old 05-27-2019, 04:40 PM
KZScott's Avatar
pull the oil pan and check for gold flakes.
KZScott is offline
post #3 of 35 Old 05-27-2019, 04:55 PM Thread Starter
Would that be shavings from the valve seat? The noise is definitely coming from the top of the motor.
Rep94401 is offline
post #4 of 35 Old 05-27-2019, 08:14 PM
KZScott's Avatar
rod bearings
its possible its spit a valve shim and its sitting in there sideways taking up all the clearance, but im guessing the noise is the piston hitting the head.
KZScott is offline
post #5 of 35 Old 05-28-2019, 05:33 PM Thread Starter
Ok, sounds like a rebuild is in store if that’s the case. Since the bike is fine otherwise, I may just do that. I bought the bike new so I’m kind of attached to it after almost 20 years of owning it.
Rep94401 is offline
post #6 of 35 Old 05-28-2019, 07:46 PM
KZScott's Avatar
its just letting you know its ready for upgrades
KZScott is offline
post #7 of 35 Old 05-29-2019, 07:13 AM Thread Starter
Haha. It’s got an expensive way of showing it.
Rep94401 is offline
post #8 of 35 Old 05-29-2019, 08:04 PM
KZScott's Avatar
its how mine tell me lol
KZScott is offline
post #9 of 35 Old 06-07-2019, 01:03 PM Thread Starter
I've got most everything disconnected and fluids drained so I'm hoping to drop the motor this weekend. I've started looking at piston kits and I'd like to go bigger with a JE 1287 kit. I plan on dropping the heads off at the machine shop too and have them go through it but do you think I should replace anything in the head ( springs/seats/etc. ) since the motor does have 55K on it and I'm planning on keeping the bike for many more years?
Rep94401 is offline
post #10 of 35 Old 06-07-2019, 06:03 PM
You should replace anything you can afford to if you are keeping it. You are already in there, so don't skimp.
Jpowell490 is offline
post #11 of 35 Old 06-08-2019, 09:24 AM
KZScott's Avatar
springs and valve seals
KZScott is offline
post #12 of 35 Old 06-11-2019, 05:04 PM Thread Starter
Thanks for the advice, guys. I don't mind spending some extra money on it since it's been pretty much problem-free all these years. I didn't get the engine dropped over the weekend as I had a hard time getting the front sprocket nut off and family stuff to do. I ended up wedging a piece of rebar in the rear wheel spokes to stop it from rotating. I'll get it dropped this upcoming weekend (I hope). I have the shop manual so I've been following that.
Rep94401 is offline
post #13 of 35 Old 06-20-2019, 10:08 AM Thread Starter
Things are starting to get serious!
ciderking likes this.
Rep94401 is offline
post #14 of 35 Old 06-21-2019, 09:41 PM Thread Starter
rod bearings
You called it. Do you think the head can be repaired? Also, there’s a couple nicks in the cylinder wall. Do you think the wider bore will grind those out?
File Type: jpeg 222AE8EC-2065-43BE-990D-A4C648458C36_1561178368362.jpeg (2.66 MB, 25 views)
File Type: jpeg B7B6E28B-5DB3-449F-9D08-AC219885622D_1561178392223.jpeg (2.47 MB, 26 views)
File Type: jpeg A8388B47-00E5-45AC-B626-69B4424CCB6B_1561178419578.jpeg (3.45 MB, 25 views)
File Type: jpeg BDB2CBF7-0D0C-49D6-8199-3C32D801F8A1_1561178442681.jpeg (4.98 MB, 27 views)
File Type: jpeg 755763A6-D1D1-4C0C-A6DE-D0A06D6570D3_1561178462822.jpeg (3.22 MB, 26 views)
Rep94401 is offline
post #15 of 35 Old 06-22-2019, 12:45 AM
Duck00's Avatar
I got the JE Piston/cylinder kit on mine, plus assorted head work & valve/cam upgrades etc. Makes a big difference in performance!
Posted my build & results in a thread under 1287 Build (I think).
Just checked, it's under "MY ZX1287 build"
Duck00 is offline
