My bike is running too much fuel and wont go! - Page 2 - Kawasaki Forum :: KawasakiWorld.com
 7Likes
post #16 of 29 Old 08-26-2019, 06:26 PM
MetalMagician's Avatar
If you had the map sensor and tps switched that map sensor is now bad for sure. I have done this once before, its very easy to mix them up. Have you replaced with a known good one since swapping the plugs? This is most likely your problem.
MetalMagician is offline
post #17 of 29 Old 08-26-2019, 11:25 PM Thread Starter
Yeah I have and it's still the same just without the fault lamp. The new water sensor is due to arrive in a couple of days so I'll fit that just to see but I might have to take the plunge with the ECU but the sounds of things.
Jkirsopmaine is offline
post #18 of 29 Old 08-27-2019, 03:57 AM
rmk
Garage
I just don't see how the water temp sensor has any influence on the fuel intake?
rmk is offline
post #19 of 29 Old 08-27-2019, 10:08 AM
SteveW's Avatar
Typically when an efi vehicle is cold, the ecu dumps more fuel in.. etc
2006 ZX-12R B6F
SteveW is offline
post #20 of 29 Old 08-27-2019, 01:29 PM
rmk
Garage
Didn't think a 12 would with having a manual choke lever compared to say a 14 which has it built in.
rmk is offline
post #21 of 29 Old 08-27-2019, 04:46 PM
SteveW's Avatar
Its not a choke lever, it's a fast idle lever.
2006 ZX-12R B6F
SteveW is offline
post #22 of 29 Old 08-27-2019, 05:15 PM
rmk
Garage
Ah, yes of course. Now makes sense that it could potentially be the water sensor. Had a look in the service manual under DFI and it shows up under a fault code. Good to know!
rmk is offline
post #23 of 29 Old 08-31-2019, 06:17 AM Thread Starter
So I've replaced the ECU now and still getting the same thing.
I've decided to test every sensor and cable now and see where that leaves me, including the water temp sensor which turned out to be fine.
I'm really at a loss here, does anyone have any other suggestions? I'm about to test the vehicle down sensor and I'm struggling to find it. Has anyone changed this before?
post #24 of 29 Old 08-31-2019, 07:13 AM
Dave Smith's Avatar
It's a long shot, but could the return fuel line be blocked?
Good luck.
I have a A1 . 2000 model ZX12R with an extra wheel.
Dave Smith is offline
post #25 of 29 Old 08-31-2019, 11:21 PM Thread Starter
Good luck.
Could be I guess, any ideas how I might test this? And also the fuel return valve I would guess
post #26 of 29 Old 08-31-2019, 11:55 PM Thread Starter
Ok so I went to test the fuel pump flow rate at the same time as making sure that the fuel lines weren't blocked so I basically disconnected the return hose from the tank, pointed it into a container then turned on the ignition. Manual says that I should expect 83ml or more from the fuel pump prime (3 secs). I turned the key like 10 tine but I didn't get any thing at all. To make sure the pump was ok I decided to do it directly from the pump outlet nozzle and got like 115 ml so the pump is fine.
Is there any reason why I might not get the fuel all the way through the injector rail and back down the return pipe under normal circumstances or should have got it?
post #27 of 29 Old 09-01-2019, 08:57 AM Thread Starter
Ok so more progress!!
With everything where it should be, it doesnt go, BUT... If I disconnect the tube for the MAP sensor, it starts and revs up running very rich, bogging down when you open the throttle (if you're gentle then it can happily rev up) backfiring and all sorts. If I have it running and reconnect the tube it dies.
Any ideas anyone? A weird one for sure.
Side note, i have actually continuity tested pretty much every single cable to every single item on this bike, everything goes to where it should and all sensors tested give the correct voltage/resistance according to the manual, including TPS, intake pressure sensor, crankshaft, Cam, atmosphere, water temp, injectors, coils, fuel pump and relay, and intake air temp.
post #28 of 29 Old 09-02-2019, 10:36 AM Thread Starter
FIXED IT!
So it turns out that the fuel strainer was split. That meant that the back pressure generated by the injector rail/pressure regulator forced the fuel out through the split back into the tank.
When you remove the tube for the MAP sensor the pump ramps all the way down to a point where the split can hold it in, meaning theres just about enough fuel for the injectors, and the engine can run.
Thanks for all the help guys, I could not have fixed this without your help and suggestions! It's a shame I've missed all if summer!
drp, SteveW and Rep94401 like this.
post #29 of 29 Old 09-02-2019, 01:36 PM
ninjayorkie's Avatar
Garage
WoW... nice find, never heard of that before. Glad to hear you've now got it sorted though.
ninjayorkie is offline
