Did I ruined my 12R by running with no oil pressure? - Kawasaki Forum :: KawasakiWorld.com
 2Likes
  • 1 Post By Warp12
  • 1 Post By rmk
post #1 of 6 Old 09-02-2019, 07:58 PM Thread Starter
yuta's Avatar
Hi all,
So I have this perfect black 2004 zx-12r . One day I completely drained the oil. Added new oil and changed oil filter. Then when I ran the bike, there was no oil pressure. I was stupid enough to keep it running for about 10mins and revved thinking it will establish pressure. STUPID~! Then I read online you will have to open the filter just a little to let air out....
Anyways.. then oil pressure came back. Bike ran normal. I went out and did 140mph. Then I parked the bike for a year. This summer, when I ran it, I felt the idle became a little rough. It surges a little. Not too much though.
Is it because of spark plugs (I have never changed it), or fuel system clogged?
It's not burning oil, that's for sure.
If there were damages due to last oil change incident, will the idle be rough? It sounds ok when revved up....
yuta is offline
post #2 of 6 Old 09-03-2019, 05:26 AM
Barbarian-CBX's Avatar
Send a message via Skype™ to Barbarian-CBX
Make sure battery is fully charged. I'd bet the plugs are fouled. Could be dirty injectors.
Sent from my SM-G955U using Tapatalk
Not just a great barbarian, the greatest barbarian, bar none!
http://www.barbarian-cbx.com/3f364190.jpg
Barbarian-CBX is offline
post #3 of 6 Old 09-03-2019, 01:27 PM
Bullstarz's Avatar
Check the balance of the throttle bodies and change the plugs.
Bullstarz is offline
post #4 of 6 Old 09-03-2019, 06:02 PM
Almost 100% dirty injectors and needs plugs. Fill your oil filter with oil before putting it on. It won't do that.
Jpowell490 is offline
post #5 of 6 Old 09-04-2019, 04:14 PM
Warp12's Avatar
All of the prior mentioned things will likely help to get you going. But, if you ran the bike without oil pressure, for 10 minutes, while revving it up....well, there could be some issues, sooner or later.
My advice to everyone is, if the oil light is on for more than a few seconds, shut it down, and try to figure out the issue.
Barbarian-CBX likes this.
Shane
Warp12 is offline
post #6 of 6 Old 09-04-2019, 11:28 PM
rmk
Garage
To add to that, if the oil light turns on (this goes for most bikes too) its probably too late already and internal damage has been done. So running the bike for 10 minutes with an oil light on tells me there must be some internal wear if not damage for sure. And then you also revved the bike. Id fear for my bigend bearings seizing up sooner or later.
Id take off the oil pan and check the internal oil filter and for any residue in the oil pan. If its copper coloured particles you find.. yikes.
rmk is offline
