Soft clutch when engine is hot - Kawasaki Forum :: KawasakiWorld.com
 1Likes
  • 1 Post By Ivan Webb
post #1 of 11 Old 09-18-2019, 11:18 PM Thread Starter
Hi fellas new to the site. I have 2000 zx12. Runs great but when it gets hot the clutch gets soft and doesnt disengage. This happens till i get through traffic run the bime till it cools off then it goes back to normal. When i say gets soft the lever is no longer solid. Gets hella slack in it like the cable is streched. Anyone have a solution?
Ivan Webb is offline
post #2 of 11 Old 09-19-2019, 09:37 AM
Yea, new clutch time
Jpowell490 is offline
post #3 of 11 Old 09-19-2019, 12:46 PM
The A1 (2000) puller rod may be flexing. It’s the part that is sticking out of the clutch cover. The cable hooks on it. The 2003-2005 puller rod is upgraded from the A1 model.
Also, in the manual it demonstrates the angle the arm should be at if your clutch pack stack height is correct. Look at that before you spend money.
color me gone is offline
post #4 of 11 Old 09-20-2019, 06:32 AM
FU
.Learn to ride on a hayabusa! Then graduate to the 12.
olajoe808 is offline
post #5 of 11 Old 09-22-2019, 02:23 AM Thread Starter
Its a brand new clutch pack and shutter spring. New clutch springs. Will the new puller rod fit the 00a1?
post #6 of 11 Old 09-22-2019, 04:31 AM
Yes
Is this where your puller rod is oriented? Take up the slack in the puller rod coil spring with pressure from your finger.
File Type: png 899F6EF1-D9E9-481F-B7BF-3458C7ABA2ED_1569152067350.png (2.56 MB, 19 views)
post #7 of 11 Old 09-22-2019, 08:54 AM Thread Starter
Yes.
post #8 of 11 Old 09-22-2019, 10:06 AM
Well, in the past, we have experienced the puller rod twisting torsionally when we pulled the clutch. Albeit we had heavy clutch springs.
The a1 model is very thin in the middle. The one that replaced it in later models is beefier.
Have you pulled the clutch cover to see if the frictions are dry? There is a oil mod that Kzscott posted. It’s a little involved but doable.
post #9 of 11 Old 09-30-2019, 10:18 PM Thread Starter
Plates arent dry. Waiting on a new rod see if that cures the problem. Whats this oil mod?
post #10 of 11 Old 12-15-2019, 08:26 AM Thread Starter
Soft clutch when engine is hot SOLVED
Replaced the 2000 puller rod with newer model 2004 puller rod.
drp likes this.
post #11 of 11 Old 12-15-2019, 11:12 PM
Hi Ivan
Reading your post I'm wondering if maybe this is part of my problem as well (noisy/audible shifting).
Where did you get the part and what part name or number is used? (tried searching clutch puler rod on ebay and didn't find anything)
Thanks,
R
2000 ZX12R Silver - 46 000Kms - MRA Double Bubble Screen - Braided hoses Back & Front - Arashi Discs Back & Front
Stock standard otherwise
rules is offline
