Fuel running noise when shut off - Kawasaki Forum :: KawasakiWorld.com
 1Likes
  • 1 Post By KZScott
post #1 of 11 Old 11-06-2019, 09:35 AM Thread Starter
Member
Big PJ's Avatar
Hi All, hoping someone can help. I’ve done a fair bit of work on my 2002 ZX12R over the last few months some of which required the fuel tank taking off. Now the bike is all back together I’ve noticed I can hear what sounds like fuel running back into the tank when I turn it off. I never noticed this before and not sure if it’s normal or not, the bike seems to be running fine. If someone could confirm if this is okay and if not what might be causing it I’d really appreciate it, thanks BigPJ
2002 A2 Kawasaki ZX12R (Blue)
1993 Yamaha YZF750R Fast Orange Replica
Bikes defy gravity, cars just suck
Big PJ is offline
post #2 of 11 Old 11-06-2019, 02:43 PM
Can you post a video so we can hear it?
I believe the 02 and up dead head the fuel line.
No return to the tank like the 00-01.
Is it the fuel pump motor whine or a liquid gas gurgling?
color me gone is offline
post #3 of 11 Old 11-06-2019, 03:15 PM
Originally Posted by Big PJ View Post
Hi All, hoping someone can help. Iíve done a fair bit of work on my 2002 ZX12R over the last few months some of which required the fuel tank taking off. Now the bike is all back together Iíve noticed I can hear what sounds like fuel running back into the tank when I turn it off. I never noticed this before and not sure if itís normal or not, the bike seems to be running fine. If someone could confirm if this is okay and if not what might be causing it Iíd really appreciate it, thanks BigPJ
It's one of those things you didn't notice before and now it's suddenly there? Whatever work you did I would back trace. Could be something simple not put back right or coincidentally a part that stopped working as it should.
olajoe808 is offline
post #4 of 11 Old 11-06-2019, 04:08 PM
KZScott's Avatar
could be the vent hissing?
olajoe808 likes this.
KZScott is offline
post #5 of 11 Old 11-07-2019, 01:23 AM Thread Starter
Member
Big PJ's Avatar
Thanks for your comments guys. I’ll see if can get a video of it but noise isn’t loud so not sure if it’ll be any help. I’ve been back over where the tank came off and can’t see anything I’ve missed or fitted back wrong. There is a feed and return line under the tank (my bike was registered 2002 but is A model) and I marked them on removal so back in correct places. It is a liquid running noise, just sounds like fluid dribbling and definitely coming from low down on tank under seat.
Big PJ is offline
post #6 of 11 Old 11-07-2019, 05:52 AM
The return line connects to a “one way” valve.
I believe kzscott has put 30psi of air pressure to activate it. Maybe it is dirty or corroded in some way. With the tank off, you will be able to take it out and clean it. If you pull the return line and it does not leak, then it is probably fine.
As was mentioned, are all the vents clear?
post #7 of 11 Old 11-07-2019, 06:26 AM Thread Starter
Member
Big PJ's Avatar
Thanks, do you know where I’d find the valve and what it looks like?
Big PJ is offline
post #8 of 11 Old 11-07-2019, 08:05 AM
Mauser's Avatar
Where about it Staffordshire are you?, is it not cooland you can hear ?
*** ZX12-R ~ RT2 360 ~ XR650R ~ DT175MX ***
Mauser is offline
post #9 of 11 Old 11-07-2019, 10:09 AM
This is a good call too. The overflow feed is down low and the thermostat as well is down low. Nice one Mauser.
The return line is attached to the valve on the bottom of the tank.
post #10 of 11 Old 11-08-2019, 07:45 AM Thread Starter
Member
Big PJ's Avatar
I’m near Cannock, fairly certain it’s coming from fuel tank not coolant but will double check over weekend, thanks again for help
Big PJ is offline
post #11 of 11 Old 11-09-2019, 10:15 AM
Mauser's Avatar
Iím near Cannock, fairly certain itís coming from fuel tank not coolant but will double check over weekend, thanks again for help
Ahhh I'm in Lichfield your pretty close :)
Mauser is offline
