Small hole in tire... Fix a flat, tire repair kit???? - Kawasaki Forum :: KawasakiWorld.com
post #1 of 10 Old 07-30-2003, 08:43 PM Thread Starter
The hole is so small it took me almost 30 minutes just to find it. There was a pin size nail in the tire, and it is leaking VERY slowly. Can I safely use fix-a-flat untill I recieve another set of tires? I do not want to use a tire repair kit b/c the hole is so small and I don't want to make it any larger using the tools provided.
Is fix a flat a bad idea???
Thanks
Chris
gtr zx12 is offline
post #2 of 10 Old 07-30-2003, 08:46 PM
How many miles left on the tire?
I got a list of demands written on the palm of my hand...
Blitzkrieg is offline
post #3 of 10 Old 07-30-2003, 08:49 PM Thread Starter
50%
At least 50%.
Thanks
Chris
gtr zx12 is offline
post #4 of 10 Old 07-30-2003, 08:50 PM Thread Starter
50%
At least 50%.
Thanks
Chris
gtr zx12 is offline
post #5 of 10 Old 07-30-2003, 09:04 PM
Fill the tire with snot, not fix-a-flat.
You can get it at any mountain bike shop, it wont hurt the rim and its organic.
A pinhole leak poses no blowout risk, so I would definitely not even think about replacing the tire.
Just my .02
post #6 of 10 Old 07-30-2003, 09:16 PM
GO 200's Avatar
gtr - WHATEVER you decide to do, make SURE you closely monitor the pressure in this tire until it is finished... Pin-hole leaks have a tendancy to get larger, sometimes, so just be aware of what's going on... :shock: :shock:
Lower tire pressure allows more flexure, thus more heat... This compounds the problem... Just watch that Beeotch!!
BTW - I'm not trying to be an azz here... :oops: :oops:
Just my $.02
I can explain it to you, but I can't understand it for you.
GO 200 is offline
post #7 of 10 Old 07-31-2003, 05:02 AM
Hmm...50% tread= maybe $75
Having to watch the air pressure, making a mess of the rim with the slime, possibility of being left stranded on the side of the road, not trusting the tire to run on at high speed..the tradeoffs aren't worth it in my opinion.
orvrider is offline
post #8 of 10 Old 07-31-2003, 05:11 AM
VinnieZX12R's Avatar
Extended burnout with 50% tread remaining... Priceless.
VinnieZX12R is offline
post #9 of 10 Old 07-31-2003, 05:24 AM
well done Vinnie!
thorgoft is offline
post #10 of 10 Old 07-31-2003, 01:56 PM
bob
I put a plug/patch in my rear tire, it only had 1500 mi. on it, worked great and gave me time to find and buy a new set.
bob is offline
tire repair kit? Jayzx-12r Good & Bad Deals 1 02-18-2012 01:07 AM
Flat tire today bldragon ZX-12R 23 04-21-2010 04:36 PM
flat tire 2quik ZX-9R 6 09-26-2004 08:31 PM
Flat tire...... ~Mono12r~ ZX-12R 10 09-20-2002 01:15 PM
