I am ordering Michelin Power Pure Set the question is which rear tire? Anyone have an opinion
true n52 i changed to a 48 rear sprocket to get my bike (close to the same) so it was a similer gear ratio:thumbup:Some people need a pic to understand.
n52 - This graphic is very good!! Is it possible to also have a plot of the stocker (200/50) included?? That way, folks can reference a known "Control"... Thanks for considering it!! :thumbup::thumbup:Some people need a pic to understand.
technology... :lol:I was looking at a side view of the 2011 ZX10. The tires on it are so tall that they almost look like bias ply tires. I've been out of the loop for 5 years, what changed?
Its not made by me.n52 - This graphic is very good!! Is it possible to also have a plot of the stocker (200/50) included?? That way, folks can reference a known "Control"... Thanks for considering it!! :thumbup::thumbup:
I've mounted those on my 12 before. I guess the bike is so small it makes the tire look big.technology... :lol:
That is a 190/55.
You old-timers have forgotten one thing, 12r is not made for the twisties.
Would have to re-do it with the base all the same, to represent the same rim width.
While the 190 and 180/55 are more of a "V" or "U" shape...
Think of the 55 series are a more pointy shape, with steeper sidewalls
Designed to give you more rubber at lean angles
Snappier, quicker turn in since the center is more pronounced
QUOTE]
Also the shape will change from mfg to mfg. i found the 2ct's v shaped compared to the 014's i switched from. both were the same size.
Unless your using it for a weekend scratcher power pure 190/55 will suit you just fine, it will handle slightly better but will not last you what so ever!I am ordering Michelin Power Pure Set the question is which rear tire? Anyone have an opinion
