I'm investing is a battery tender / charger this winter... would you guys remove it and store it inside while hooked up? Or does it really matter? The battery has about 300 miles on it from this summer.
+1 Awesome chargersI have put an optimate charger on mine. They supply a connector that wires onto the battery so you dont have to remove anything. It charges as required and then monitors every hour if a quick squirt of charge is required it does it and then checks again in a hour. I have an alarm / immobiliser fitted so this is a must. Charger is about 40 UK pounds.
