After reading Blitz's excellent article on Kleen air removal and PCV mod, I started to read the section on Kleen air in the service manual.
For my novice eyes it appears that the vacuum at the stacks between the airbox and the engine inlets controls the Kleen vaccuum valve which allows air to flow through the reed valves into the exhaust.
If you remove the Kleen system entirely and route the PCV line to the reed valves then there should be suction at this point all the time (when the engine is running) with no control by the vacuum valve. This valve appears to stop counter flow from the exhaust back into the airbox which it would also do if the PCV was routed through it.
This is a bit rambling but the question is??? Is it better to leave the vacuum valve in place and route the PCV line to the inlet to the vacuum valve assembly??
